Friday, Jul 03, 2015 at 19:50
Member - Broodie H3 posted:
thank you all for your valuable input, the weight of the van should come in at around 1850 kg when completed, it will have a simplicity
suspension under it and when fully loaded she should weigh around 2500 kg
In that case a 205 x 16 LT could be ideal providing you can get them in highway pattern.
My little ute weighs 1600 kg.The handbook says it is considered to be empty with a load of two people and up to 100 kgs of luggage. I thought a couple of average size people would weigh about 75kg so with another 100 of whatever on board the car would weigh 1850. GVM is 2500kg. This means I could add another 650 kg to it.
Factory pressures are 25 psi front and rear when empty and 25 to 34 rear depending on load. This gives a variation of 9 psi.
The tyre manufacturer gave me a lot of information about them including a 1 psi increase would support an additional 70 kg.
650 kgs divided by 9 equals 72 kg which ties in with each additional psi supporting an additional 70 kg.
Those pressures and that adjustment at the rear depending on load have worked perfectly over the last seven years everywhere from remote sandy Beadell roads to coastal mountain tracks.
I think it would be worth your while choosing your favorite brand of tyre then ringing the manufacturer. You have to start somewhere when making your final decision so that would be as good a place as any.
842870
