landcruiser gearbox to transfer case hose
Submitted: Tuesday, Apr 13, 2004 at 16:55
Member - glenno (QLD)
If i put on a hose to equalise the pressure between the gearbox and the transfer case does it connect between the filler plugs or the drain plugs . T he guy where the kit is bought from says definately the drain plugs . I saw in a 4wd magazine where they connected the hose between the two filler plugs .
Reply By: Pesty - Tuesday, Apr 13, 2004 at 17:01
Hi Glenno
Definetly to filler plugs and make sure your connections are steel not brass.
Been running them for many years on several cruisers
Cheers Steve
54039
Follow Up By: GO_OFFROAD - Tuesday, Apr 13, 2004 at 17:41
Split the case and box and fix the seal instead.....
Why put a band aid on it.
315695
Follow Up By: Pesty - Tuesday, Apr 13, 2004 at 17:49
Major operation to replace the seal which only lasts a while, when fitting the hose is cheap, easy, and affective. Go with the hose.
315699
Follow Up By: GO_OFFROAD - Tuesday, Apr 13, 2004 at 17:52
I wouldnt say removing the t/case was a major operation, I have done
mine on my other cruisers before without a problem, and if all the seal running surfaces are in good condition the seal should see 150k + if using a factory seal.
315701
Follow Up By: Rod E B - Saturday, Apr 24, 2004 at 14:47
once more , and slowly for the dummy
do I understand that i can reduce the leaks I get in my 1985 cruiser FJ62 which I have had repaired several times
The leakage greater just after each service .
To reduce the leaks I get some
hose ( what sort )
some fittings ( what sort )
and join the gearbox and transfer case filler holes.
Is it the same for an Automatic
from the previous post it sayes " a kit can be purchased"
if so where
Rod
317605
Reply By: Member - Bradley- Tuesday, Apr 13, 2004 at 17:17
Yup, definetely the filler plugs, can't see a problem with using brass connections though, plenty of teflon tape on the threads and use full stainless 'solid' wormdrive clamps.
Think about it, what happens if you somehow pierce the hose or snag it on something and tear it loose, if it is connected to the drain hose - leaky leaky, grindy grindy, sweary sweary, empty wallet, :-((((
Do it like roothys efforts, and a good idea would also be to get some 'p' clip brackets to secure the hose to the gearbox/ trans case for extra protection.
BTW nice shot of the troopy, looks MAP ( Mean As P...)
54041
Follow Up By: Pesty - Tuesday, Apr 13, 2004 at 17:29
Some brass connections are not very thick walled and can crack.
Cheers Steve
315693
Reply By: Davoe - Tuesday, Apr 13, 2004 at 17:19
yes filler not drain. Just a point I noticed my tc leaking oil from varios seals/gaskets so I drained it to the correct level and topped up the gearbox so the gear box had been putting oil into the t/c with no leveling of fluids oh and it fixed the leaks
54042
Follow Up By: Davoe - Tuesday, Apr 13, 2004 at 17:28
Oh
yea I have brass fittings and they are a pain for double threading
315692
Reply By: Member - glenno (QLD) - Tuesday, Apr 13, 2004 at 18:14
Thanks for the help . appreciated .
54053
Reply By: Willem - Tuesday, Apr 13, 2004 at 22:57
Yeah...filler plugs. Had one on my FJ55. Carry some spare hose because I snagged the hose a few times doing cross country work. You soon know when the hose breaks...that beautiful smell of gear oil !!! I used steel connections.
54108
Follow Up By: Member - glenno (QLD) - Wednesday, Apr 14, 2004 at 13:48
thanks willem cheers
315829
Reply By: DiesAl - Wednesday, Apr 14, 2004 at 12:27
Sorry, excuse my ignorance but why do you need to equalise the pressure between Gbox and Tcase ??
54166
Follow Up By: Moose - Wednesday, Apr 14, 2004 at 13:51
It's not pressure that is equalised. It's the fact that some Cruiser models have a nasty habit of transferring oil from one to the other (can't recall which way). End result is one is low on oil and the other over full. The hose ensures they both stay at the correct levels.
315830
Follow Up By: DiesAl - Wednesday, Apr 14, 2004 at 14:03
Thanks Moose, did you just get back from Northern NSW??
315831
Follow Up By: Moose - Wednesday, Apr 14, 2004 at 14:11
OK DiesAl you've got me at a disadvantage. Who am I corresponding with?
Was back at work yesterday. We had a fantastic time over the
Easter break. Wasn't cold (although I enjoy the cold weather) and it didn't rain which was a bloody miracle because it always has whenever I've been to that area.
315833
Follow Up By: DiesAl - Wednesday, Apr 14, 2004 at 14:18
My parents went away with you........Rod & Noeleen
315834
Follow Up By: Moose - Wednesday, Apr 14, 2004 at 14:35
It's always a pleasure to have them on a trip. Pity it's only once a year these days. Will we see you in the Club one day or are you not in Brissie?
315835
Follow Up By: DiesAl - Wednesday, Apr 14, 2004 at 14:46
It's quite possible!!!! I'm actually closer to Brissie than they are now....
315837
Reply By: Rod E B - Saturday, Apr 17, 2004 at 13:49
hose ( what sort )
Rod
54679
