2 inch bodylift 96 ford courier
Submitted: Tuesday, Apr 13, 2004 at 19:38
rickster
G'day everyone just thought I would drop a line about body lift for ford courier.
I have just finished lifting
mine up 2 inches,no major problems only had to move
the gear shift boot,radiator shroud and the bull bar everything else is fine.
Looks great and protects my seals.
Reply By: Truckster (Vic) - Tuesday, Apr 13, 2004 at 19:57
What seals? Door seals? window seals? Navy Seals?
54067
Follow Up By: rickster - Tuesday, Apr 13, 2004 at 20:38
G'day truckster that would be my pet ELEPHANT SEAL !!!!!!!!!!!!!!!!!!
315730
Reply By: Member - Peter D M - Tuesday, Apr 13, 2004 at 20:14
hi rickster, did you buy a kit or assemble parts yourself ? more details would be great.
54069
Follow Up By: rickster - Tuesday, Apr 13, 2004 at 20:35
G'day peter I made the kit myself,I bought a metre of 50 mm polyethanine tube cut it into 2 inch lengths, drilled 12 mm hole in the center.Got 10 x 12mm x 80mm hi tensile bolts with nylock nuts and 4 x 12mm x 150mm hi tensile bolts with nylock nuts and 28 flat washers.
315729
Reply By: halfinch - Tuesday, Apr 13, 2004 at 21:22
howdy rickster, just wondering main reason for the lift? was it bigger tyres if so what size? also did you have trouble with brake/fuel line etc
54083
Follow Up By: rickster - Wednesday, Apr 14, 2004 at 22:41
G'day I wanted to put 33" muddies on, so it was mainly for guard clearance.As for brake/fuel lines no problems there
cheers rickster
315941
Reply By: Member - Peter D M - Thursday, Apr 15, 2004 at 06:16
hi rickster, thanks for the info. an easy way for more clearance, on a rodeo its a bit more complicated, radiator, front bumper, brake lines etc. i run 32's with no probs but a lot of
suspension work. regards peter.
54305
Reply By: neviam - Thursday, Apr 15, 2004 at 23:11
Hi rickster, any picks? I am doing my Raider in a week or so. The blocks I'm going to use are 50mm x 60mm. Can you see any problem with the extra 10mm width?
54457
Follow Up By: rickster - Friday, Apr 16, 2004 at 19:10
G'day neviam there shouldn't be to many problems, if you send me your email address I will send you a few photos.
cheers rickster
316223
Follow Up By: halfinch - Friday, Apr 16, 2004 at 22:34
howdy rickster, whats the safest way to send email address because I'd really appreciate some pics, i have a 96 extra cab courier with 30/9.50-15's and really want to go bigger.
thanks halfinch
316287
Follow Up By: neviam - Saturday, Apr 17, 2004 at 06:49
Rickster, my email address is nev@bigfoot.com.au thanks. Nev (neviam)
316310
