NISSAN GQ L.S.D.
Submitted: Sunday, May 26, 2002 at 00:00
ThreadID: 1207 Views:3490 Replies:5 FollowUps:1
I have a NISSAN GQ Diesel and have discovered the L.S.D. has given up. The question is: 1. replace, refurbish. 2. Detroit Locker or similar. 3.ARB Diff Lock. What will be the best cost effective choice. I do a lot of off road work, with some towing in the future. Any suggestions would be great. Edwin.
Reply By: colin - Monday, May 27, 2002 at 00:00
before spending big dollars try replacing the diff oil as lsd oil is self depleating and ends up makeing the diff make some strange sounds when turning, i had the same problem in my gq and didnt beleive changeing the oil would solve the problem. Was also told the nissan lsd is one of the stongest on the market and should stay with it if possible. Col
AnswerID: 3859
Reply By: Edwin Callard - Tuesday, May 28, 2002 at 00:00
Colin Thank you for your advice. As it so happens I have just booked it in for a major, so will see how it goes
AnswerID: 3876
Reply By: Andrew O - Wednesday, May 29, 2002 at 00:00
Be aware that LSD oil is different to normal diff oil - ensure the mechanic uses the correct stuff as this makes a significant difference too. The Nissan LSD is virtually bullet proof. Cheers - Andrew
AnswerID: 3884
Follow Up By: Shane - Sunday, Jun 02, 2002 at 00:00
the correct oil is 85/140 lsd oil. if you fit the more normally available 85/90 lsd oil it will shudder and wont work as good.
shane
FollowupID: 1677
Reply By: shane - Sunday, Jun 02, 2002 at 00:00
you can get them machined up for around 300 bucks at "on track 4wd" in moss st springwood.
shane
AnswerID: 3966
Reply By: Kezza - Wednesday, Jun 12, 2002 at 00:00
In Nissan Patrols Use Penrites limslip 140 not the 95 /140 We run 2 patrols a GQ and GU and you will be amazed, the patrol is the only 4wd that the 140 is suited to cures the shudders and noises makes for much beter traction and I mean MUCH better. check out I actually gave penrite my endorsmenthttp://www.penrite.com.au/db/newslist.php
AnswerID: 4140
