Solar Panel .
Submitted: Friday, Apr 16, 2004 at 21:16
Member Eric
Does anyone here , know what a 1000 watt Solar panel is worth ? including the control box ?
Thanks guys
Reply By: Boeing - Friday, Apr 16, 2004 at 22:02
Eric You will need a semi to move it but on the plus side you will have enough power to supply
Geelong... LOL
I think you mean 100 watt
mark
54620
Reply By: Bilbo - Friday, Apr 16, 2004 at 22:05
Eric,
Are you sure it's "1000 watts"? That one hell of a size solar panel. That should pump out about 75 to 80 amps at 12 volts. The regulator wouldn't be cheap either. 1000 watts - phew!
Bilbo
54621
Reply By: Bilbo - Friday, Apr 16, 2004 at 22:07
Eric,
Are you sure it's "1000 watts"? That's a hell of a size solar panel. How big is it physically. That'd push out about 75 to 80 amps at 12 volts. The regulator wouldn't be cheap either!
1000 watts - phew!
Bilbo
54622
Reply By: Bros - Friday, Apr 16, 2004 at 22:29
G'day eric,
1000 watts. Thats some serious power. A 900 watt system will set you back around $13,000 less Gov rebate of $3,600. A 1050 watt system around $14,000 less rebate of $4,000. Chuck out about 6KW a day. If you mean 100 watts, then a google search will probably find you something.
Cheers Bros.
54630
Follow Up By: STAN - Saturday, Apr 17, 2004 at 01:44
G'day Eric , Any size solar panel will cost you about $10 PER watt if bought new check them out on the net e:g www.tasmanenergy.com.au OR wwwfridge-and-solar.com.net are just 2 Cheers, Stan
316307
Follow Up By: STAN - Saturday, Apr 17, 2004 at 01:45
316308
316309
Follow Up By: William - Saturday, Apr 17, 2004 at 20:02
$8.00 per watt is the absolute maximum price.
316391
Reply By: Member -Bob & Lex (Sydney) - Saturday, Apr 17, 2004 at 07:22
Kyocera 120w panel $990 + regulator $88
54659
Reply By: Member Eric - Saturday, Apr 17, 2004 at 09:21
it is big . It takes up 1/3 of the full length roof rack , I will have a closer look tonight , At least I learnt something , the white box is the relay ? . I will get the numbers tonight
54663
Reply By: David N. - Saturday, Apr 17, 2004 at 12:58
120 watt is normally the biggest you'll get.
1,000 watts would be nice, but sorry it aint possible. Maybe some day....
54676
Reply By: William - Saturday, Apr 17, 2004 at 18:39
What do you want to run from the solar panels?
Suntech Australia have the 80w solar panels for $656 this month.
Regulator from Jaycar MP3126 $69.95
54706
