80 Series Diesel Maintenance
Submitted: Tuesday, May 28, 2002 at 00:00
Stan Lawler
Do 1HZ Engine fuel Injectors need to be cleaned / serviced at regular intervals. My cruiser has just clocked 100 000 klms and is not blowing much smoke, but is this the only
sign that they need a clean. Is it worth while getting the timing checked and anything else to keep it running
well. While I am asking questions, is Castrol RX Super oil OK, and are Fleetguard filters allright, or should i buy genuine filters.
Reply By: Steve - Tuesday, May 28, 2002 at 00:00
Stan,
At 100,000 kms I would be lookoing at an injector service. My Cruisers have all had their injectors done at 60,000 kms, and although they were not blowing smoke, there was a noticable difference in performance before an after.
3867
Reply By: Goran - Tuesday, May 28, 2002 at 00:00
Stan , you should be able to cover lot more kms without major injector service . There are other signs of injector trouble such as rough idling , loss of power etc. I had great resoults with NYLON Diesel injector cleaner . I use it every 7000-10.000 km and my Cruiser is still going as strong as ever and no smoke at all . You can check the timing and valve clearance , it doen't hurt .
3874
Reply By: Steve - Wednesday, May 29, 2002 at 00:00
Stan, Goran is right, you should be able to go for longer withoout a major service. However, you should get the spray patterns checked at more frequent intervals. Doesn't cost much and a clean at the same time keeps the diesel perfroming like new. As for usin injector cleaning things......I'll leave that up to you, but I am very wary of $20 addatives in my $10,000 km motor.
3890
Reply By: Ian B - Friday, May 31, 2002 at 00:00
1HZ's will tolerate bad injectorsquite a bit before smoking and giving really bad economy or low power. This doesn't mean they are in good condition.
Pulling them and having them checked is a lot cheaper than a cracked head which is the likely outcome on a 1HZ from poor spray patterns or bad tuning.
Ian B
3943
Reply By: Cruiser - Saturday, Jun 01, 2002 at 00:00
For an answer on injector servicing read the article in June issue of 4x4 Australia, p. 115. By the time you get to p. 118 you'll wonder why you left it so long.
3948
Reply By: Derek - Saturday, Jun 22, 2002 at 00:00
Stan. My 80 series reached 130,000 ks when I met a fuel injection
shop owner who said the injectors of any diesel engine with indirect injection would need servicing at 100,000ks and that
mine were probably already giving trouble but I coudn't notice it. Despite having no apparant problems, I took his advice and guess what....there was nothing wrong with them. I've used Fleetguard filters in the earthmoving game for 20 years and never had any problems. Happy motoring!
4358
