Intercoolers
Submitted: Tuesday, May 28, 2002 at 00:00
Doug
I am looking at putting a Safari intercooler on my 96 GQ nissan 2.8 turbo patrol and am interested in hearing from anybody that has done this or any one that knows anything about them do they make any difference. Doug
Reply By: Cairns Offroad Training & Tours - Wednesday, May 29, 2002 at 00:00
If you haven't already done so a computer upgrade of your injection system would be far mor beneficial and cheaper than an intercooler.
Cheers Rob
3893
Follow Up By: Doug - Wednesday, May 29, 2002 at 00:00
Rob
If you dont mind could you explain what this computer upgrade is as I thought it had a machanical pump on it. Regards Doug
1657
Reply By: Billowaggi - Thursday, May 30, 2002 at 00:00
Hi Doug You'r 2.8 Patrol has a mechanical injector pump but
the governor, fuel metering. timing and throttle control is electronic, have a look under the dash at the top end of the accelerator pedal I think you will find that the only connection is a wiring harness to the computer! My main experiance is with 2.8 GU Patrol but I am pretty shure GQ is the same Regards Ken.
3933
Follow Up By: John Sullivan - Thursday, Jun 06, 2002 at 00:00
The GQ is not the same as GU. No electrics or computers, mechanical pump etc. Am currently looking at the same thing. Will post results when I have got some results. May be a couple of months until all research is completed. Hope this helps.
1728
