Arrid 12 volt sockets / plugs
Submitted: Sunday, Apr 25, 2004 at 00:39
rolande
Has anyone used this type of socket?
www.uni-solar.com.au/ARRID/plugs.html
Rated at 20 amp so am looking at for fridges, etc. Look to be O.k. as they fit normal cig' lighter type plugs as
well as hella plugs
Any thoughts appreciated
Rolande
Reply By: Pluto - Sunday, Apr 25, 2004 at 07:36
I've been using them for a three years now, and I think they are a very good plug. Particularly the PAP8 & PAP15 . I have heard a few bad reports of the Hella plugs that use the format but have experienced no breakages with the Arrid plugs.
All of the outlets from my second batery use this format. I only use the Universal plugs where I know the equipment is going to be used on a conventional Cig socket, from time to time.
I recommend you use the surface mounted sockets (PASS) instead of the flush mounts because the grip on the plug does not protrude into the space, around it. This protects the plug against knocks.
55828
Follow Up By: rolande- Sunday, Apr 25, 2004 at 15:14
Thanks, was looking at fitting two, maybe three but wanted something that would run heavier items as
well without going to anderson plugs, etc. Will look at further now, thanks for the reply
Rolande
317721
Reply By: Member -Bob & Lex (Sydney) - Sunday, Apr 25, 2004 at 14:28
I have put them on all our stuff as car is cig sockets & camper is hella sockets & they work fine but for fridge I have used anderson plugs.
55858
Follow Up By: rolande- Sunday, Apr 25, 2004 at 15:17
Was looking at the ARRID sockets in the vehicle as want to have the ability to run several different things, compressor, etc, from different points. Was not looking specifically at running the fridge through one all the time, just now and then. They look better than the anderson plugs as
well but I can see the value of the good connection with the anderson's
Rolande
317722
Rolande
317723
Follow Up By: rolande- Sunday, Apr 25, 2004 at 15:19
two be sure, two be sure. Don't know how that happened, didn't think the follow-up was that good! thanks again
rolande
317724
