Tyre levers for splits
Submitted: Sunday, Apr 25, 2004 at 16:56
ThreadID: 12358 Views:4085 Replies:6 FollowUps:0
Hi All, Been having trouble tracking down a set of tyre levers, can't believe the number of auto shops that don't carry them.. Need them for my Toyota splits, anyone recommend a place in Sydney if possible where I could buy a "decent" pair? Bought a "supercheap" pair from Supercheap autos who where the only place I could find locally with them and guess what, cracked the ends off before I could even get the ring off one rim. What ever happened to quality steel? Hope someone can give me a few clues, thanks, Peter
Reply By: KiwiAngler - Sunday, Apr 25, 2004 at 17:33
http://www.4wdworld.com.au/outlets/4wdwarehouse/
ADDRESS: 1/12 GARLING ROAD
KINGS PARK NSW 2148
PHONE: 02 9622 1000
FAX: 02 9831 4735
WEBSITE: www.4wdwarehouse.com.au
EMAIL: Click here
PROPRIETORS: SLAV STEFANIK,
CRAIG RUTING
SALES: SCOTT BUTLER
MICHAEL ELLIOTT
HOURS OF OPERATION: MONDAY-FRIDAY: 8.00 a.m. - 5.30 p.m.
SATURDAY: 8.30 a.m. - 2.30 p.m.
AnswerID: 55876
Reply By: mac1 - Sunday, Apr 25, 2004 at 17:37
Go to any tyre shop
Beaurepairs Brigstone Bob Jane etc
AnswerID: 55877
Reply By: Phil G - Sunday, Apr 25, 2004 at 20:28
With split rims, I used to use a Mumme brand tyre lever to move the ring, so I could then insert a very large screwdriver into the slot to lever off the ring. Could have done the same with two screwdrivers I guess, and left the tyre levers at home.
AnswerID: 55903
Reply By: Eric Experience. - Sunday, Apr 25, 2004 at 22:02
Peter.
IF your rims are clean and free of rust you do not reqiure any levers, only a screw driver to get the ring started. If you get you rims sand blasted then pianted with a 2 pack piant the tyre will come off with your hands. I assume you are pushing the tyre down past the sholder on ring before you try to remove it. It should be easy. Eric.
AnswerID: 55917
Reply By: Peter 2 - Sunday, Apr 25, 2004 at 22:32
I've always used two large screwdrivers after breaking the bead (with the tyrepliers) and as others have said making sure the bead is below the ring before you try to lever it off .
AnswerID: 55932
Reply By: Oznuggets - Monday, Apr 26, 2004 at 09:57
Thanks guys, Yes I had broken the bead before trying to remove the ring. The rims are in pretty good condition and have all have all been apart in the last 12 months. Just looking to perfect my skills in replacing the casings etc myself to save on carrying the extra spares with rims. I'll give the screwdriver option a go as I have a couple of larger ones laying around and was lucky enough to score a good "old" aussie made tyre lever last night off a mate so can use that to lever the ring and put screwdriver in the slot, cheers all, Peter
AnswerID: 55974
