A definate recovery item.......
Submitted: Wednesday, Apr 28, 2004 at 09:40
ThreadID: 12446 Views:2264 Replies:11 FollowUps:7
I have seen a lot of people ask about what gear is a must in a recovery kit....
I have found that a throttle cable doesnt go astray.... You may think it is silly but wait till you brake one....
Reply By: Davoe - Wednesday, Apr 28, 2004 at 10:18
I dunno think of all the xtra stuff you would see from birdsville to darwin via lawn hill ...... at idle speed
AnswerID: 56359
Reply By: Member - Bradley- Wednesday, Apr 28, 2004 at 10:43
Take a leaf out of the WRC (world rally champs) book, have seen many occasions where the co-driver has to whip out the laces from their shoes and set up to pull the throttle body manually through the window ! Have also seen one crew finish a stage with the bonett up on the windscreen , drivers head out window, co-driver laying across the engine bay working the throttle to the calls of the driver. Looked like fun NOT... These guys come up with some amazing tricks to finish races.
Seriously, yeah not a bad idea, could be stuffed in behind a panel real easy.
AnswerID: 56363
Reply By: uppy - Wednesday, Apr 28, 2004 at 11:33
Hi Voxson,thats good advice . How much do they cost.Ill carry one in my set up.I hope all is well
regards the uppies
AnswerID: 56370
Reply By: Voxson (Adelaide) - Wednesday, Apr 28, 2004 at 13:43
Well,, i know the part number for td4.2 gq is 1820102500 $37.50 icl gst...from nissan...
AnswerID: 56390
Follow Up By: Member - Rick (S.A.) - Wednesday, Apr 28, 2004 at 18:49
Voxson, old son
Where ya been?
How's it going for the bg trip preparation............I guess this thread is telling me????
Have a good one & we'll look forward to a comprehensive trip report when you land back here.
FollowupID: 318161
Follow Up By: Voxson (Adelaide) - Thursday, Apr 29, 2004 at 08:02
Hi Rick... I should change the tagline because as of last week the trip has changed to the Simpson only....
I have 5½ weeks off work and i have a new house settlement of 12may so i decided (handbrake) to use the second ½ of time off to move house...(if i get back on time)....
FollowupID: 318263
Reply By: Wazza (Vic) - Wednesday, Apr 28, 2004 at 15:46
We broke a throttle cable a Mitsubitshi truck when I used to work weekends as a furniture removalist for Telstra. We hooked up a bunch of mouse leads from the PC's we were carrying at the threaded it through the grill, under the bullbar into the cab. Worked a treat as a hand throttle to get us back to the warehouse.
AnswerID: 56410
Reply By: Rick Blaine - Wednesday, Apr 28, 2004 at 17:40
Strewth... My jack dosent have a throttle cable....maybe I'll have to keep to civilisation?
AnswerID: 56425
Reply By: Willem - Wednesday, Apr 28, 2004 at 19:49
I carry a couple of metres of tie-wire....good for fixing lots of things.
AnswerID: 56448
Reply By: Member - JohnR (Vic) - Wednesday, Apr 28, 2004 at 20:57
Voxson, the GU 4.2 has a hand throttle there already, how many more should I carry?
AnswerID: 56465
Follow Up By: Voxson (Adelaide) - Thursday, Apr 29, 2004 at 07:59
If the GU is the same as the GQ the hand cable only goes to the pedal...
FollowupID: 318259
Reply By: Member Eric - Wednesday, Apr 28, 2004 at 22:04
if you brake a accelerator cable , why not just screw the revs up a little , you wont fly , but you will get home . 1200 rpm , should be good for 70kmh
AnswerID: 56480
Follow Up By: Voxson (Adelaide) - Thursday, Apr 29, 2004 at 07:57
Hi Eric... Thats a great idea if you are not in the middle of the Simpson or still trying to cross swollen rivers.....
FollowupID: 318257
Reply By: Member - Toonfish - Wednesday, Apr 28, 2004 at 23:37
so fly by wire should we carry a spare sender/actuator?
just kidding
AnswerID: 56502
Follow Up By: Voxson (Adelaide) - Thursday, Apr 29, 2004 at 08:05
I am a shocker for spares... I carry water pump, brushes for starter and alt, slave cyl, etc... too much but you never know
FollowupID: 318264
Follow Up By: Member - Gajm (VIC) - Thursday, Apr 29, 2004 at 08:53
You can't go wrong carrying spares...looking at your list i need to add a few, do you carry 10l of oil too?
FollowupID: 318271
Follow Up By: Bonz (Vic) - Thursday, Apr 29, 2004 at 18:20
What spares have u used before, that may give u a guide. and if u have a 3.0 Patrol maybe a spare short motor could be useful
FollowupID: 318356
Reply By: Member - Nigel (QLD) - Thursday, Apr 29, 2004 at 20:47
I once drove the old suzuki home using plastic clothesline rope for a throttle cable - had to stop every 50 km or so to retension it :)
AnswerID: 56615
