Adjusting Headlights
Submitted: Friday, Apr 30, 2004 at 09:26
ThreadID: 12501 Views:3227 Replies:3 FollowUps:3
Hi all. Getting down to the last to do before we head of up north. I have checked in the archives but can not find anything on how to reajust the headlights. I can remember seeing in a garage a yellow board with black lines on it reposition the lights but that was long time ago. Has any one got the proper formula, web sites or other information for Nissan Terrano? Thanks in anticipation.
Reply By: Davoe - Friday, Apr 30, 2004 at 09:56
should be in the archives somwhere coz this subject has come up a few times. but anyway forget the boards lines garages or whatever and drive down a little used road (at night) and throw your jacket over one light while adjusting the other then go for a quick drive to confirm you are happy with it then make any further(small adjustments. make sure you allow for the xtra weight you may be carrying up north
and carry a torch for finding the adjusting screws/bolts and make sure you know where they are and they are working and not seized as it is a pain mucking around with this sort of thing on the side of the road in the dark --- have a good trip
AnswerID: 56681
Follow Up By: Raindeer - Friday, Apr 30, 2004 at 09:59
Thanks. I think I was thinking to scientificaly.
FollowupID: 318419
Follow Up By: Truckster (Vic) - Friday, Apr 30, 2004 at 10:58
4wd forum, not filled with scientists...
You can actually buy the machine that they use when you have a car inspected, $2800 for them, and considering yo u would only use it once in 10 years.. good investment,
FollowupID: 318427
Reply By: Raindeer - Friday, Apr 30, 2004 at 11:01
Maybe not but some of you are very cluey. Must be years of experience with 4b's.
AnswerID: 56689
Follow Up By: Shaker - Friday, Apr 30, 2004 at 18:29
The best answer was the first answer .... do it on a quiet road. I always did it that way when I wa a kid.
I have a Terrano 2 & recently asked the auto elec about headlight adjust ... he said .... " do it on a quiet road"! Which is how he does his own!
BTW .... Terrano 2 inherently has sh**house lights !!!!!!
FollowupID: 318490
Reply By: Hedonist - Friday, Apr 30, 2004 at 14:03
You can get it pretty close using this method:
1) Find a vertical wall near a flat, level surface - driveway or carpark etc.
2) Drive the vehicle right up to the wall, and mark the exact position of each headlight on the wall.
3) Backup about 5 metres and adjust the headlights on high beam so that the brightest point of light is on the cross marks.
I always follow this up with a check as described above, but it will give you an acceptable adjustment on its own.
Pete
AnswerID: 56713
