Site Search
Section Image
DUAL BATTERY SELF INSTALLATION
Submitted: Monday, May 03, 2004 at 19:07
GQMAVERICK
HI FOLKS COULD SOMEONE ADVISE ME OF THE BEST WAY TO INSTALL DUAL BATTERIES. IE. BASIC WIRING DIAGRAM AND THE ADVICE ON SOLENOIDS ETC TO USE WITH THIS.
Advertisement
ThreadID: 12571 Replies: 7
Views: 826 FollowUps: 2
AnswerID: 57062   Submitted: Monday, May 03, 2004 at 20:03
Truckster (Vic) replied:
www.rotronics.com.au I think it is, call them they will send CD with their kit on it.. Also on the cd is instructions on how it is setup.. Just do the same.
I got the Piranha kit, well worth the $ 1 hour to install...
Reply 1 of 7
FollowupID: 318889   Submitted: Tuesday, May 04, 2004 at 11:41
uppy posted:
Hi Truckster,How much did it cost and can you install them into a efi
regards uppy
FollowUp 1 of 2
FollowupID: 318925   Submitted: Tuesday, May 04, 2004 at 17:04
Truckster (Vic) posted:
Cost a few 100, and installed easy as pie myself..
Fit an EFI, I cant see why not.
FollowUp 2 of 2
AnswerID: 57071   Submitted: Monday, May 03, 2004 at 20:42
Groove replied:
Hi GQMaverick
I installed a rotronics unit myself and it wasnt too difficult. The instructions that came with the rotronics had plenty of diagrams that were easy to follow.
You can also buy the required cables already made up from rotronics with the right lugs at each end. If you prefer to make your own I found BIAS boating to be a great source of electrical cable, connectors, merrit plugs, cig plugs and sockets etc.
Groove
Reply 2 of 7
AnswerID: 57072   Submitted: Monday, May 03, 2004 at 20:42
Groove replied:
Hi GQMaverick
Groove
Reply 3 of 7
AnswerID: 57088   Submitted: Monday, May 03, 2004 at 21:31
Member Eric replied:
I believe the Kiss method is best now . keep It Simple Stuped . connect both batteries together , make sure both are earthed , fit a isolater for overnight stay's if you goint to keep the fridge running in the car , cant fail .
Click Image to Enlarge
GO HARD OR GO HOME
Multi air bag Caddy
Reply 4 of 7
Activities Index
V8 Supercar Hot Laps Racing Event V8 Supercar Hot Laps Racing Event
Sydney - NSW
Bring your family and experience Holden & Ford V8 Supercars racing the clock in a 10 km race wit
Awegasmic Whitsundays 6 days/5 nights DORM Awegasmic Whitsundays 6 days/5 nights DORM
The Whitsundays - QLD
Whitsunday Island holiday package including coach and vessel transfers, backpacker accommodation at
V8 Race Buggies Intro Drive - GOLD COAST V8 Race Buggies Intro Drive - GOLD COAST
Gold Coast - QLD
Get a taste of what racing a V8 Off Road Buggy is all about right here in Queensland.
Ultimate Thrill Ride - 3 Hot Laps in a WRX STi Ultimate Thrill Ride - 3 Hot Laps in a WRX ST
Gold Coast - QLD
Guaranteed front seat for you in a WRX STi Rally Car !
Book Now - Things To Do
AnswerID: 57134   Submitted: Tuesday, May 04, 2004 at 10:18
Member - AndrewPatrol replied:
This might seem basic common sense but make sure you do it. Remove and tape up the original battery leads while working on the installation. you can easily short and blow up goodness knows what in todays cars!!!!!!!!! I'll leave the rest to your imagination
Reply 5 of 7
AnswerID: 57172   Submitted: Tuesday, May 04, 2004 at 13:59
Moose replied:
If you want to keep it simple just buy a heavy duty solenoid. Has 2 large and 2 small "posts". Connect wire (thick stuff) from positive on starting battery to one of large post and same sized wire from other large post to positive of aux battery. One of the small posts is for power and other is the earth. Power source needs to be from somewhere that when the ingition key is off there is no power to the solenoid. So when you turn the key on the batteries are connected and both can be charged. When ignition is off the batteries are isolated and you can't flatten the starting one. If you wish to you can add in an on/off switch in the cabin so that you can manually override when to switch it on and off. This is particularly useful if the aux is a deep cycle. Stops it being used to help start the car and thus getting drained quicker. Once those deep cycles are down on power the alternator simply cannot recharge them so it's best to not use them to start the car. That's pretty simplistic - you can find diagrams on the net if you search around a bit.
Reply 6 of 7
AnswerID: 57210   Submitted: Tuesday, May 04, 2004 at 18:29
GQMAVERICK replied:
HI GUYS
THANKS TO ALL WHO REPLIED I WILL BE OUT TOMMOROW TO PICK UP THE ESSENTIALS AND THEN OFF TO THE AUTO LECCY TO ENSURE I DID IT RIGHT. THANKS ONCE AGAIN.
COLIN
Reply 7 of 7
