Site Search
Section Image
Front hubs
Submitted: Monday, May 03, 2004 at 22:48
marklynn
Just a quick question......Should front hubs be left locked or unlocked when not in 4 wheel drive mode
Advertisement
ThreadID: 12585 Replies: 7
Views: 422 FollowUps: 3
AnswerID: 57110   Submitted: Monday, May 03, 2004 at 23:11
Des Lexic replied:
For economy, Hubs are best left unlocked however once a month or so, lock them in for a few k's to keep them lubricated.
It's not the years of your life that matters, it's the life in your years that count.
Reply 1 of 7
AnswerID: 57112   Submitted: Monday, May 03, 2004 at 23:15
Member - Roachie (SA) replied:
My suggestion is to leave them unlocked all the time. Only need to lock them in when you're about to do some 4 wheel driving. It saves wear on front drive components.
I usually lock them say in a car park or at camp etc just before heading into any rough stuff etc.
However, I also believe in having them locked and using 4 wheel drive when driving on gravel roads at normal speeds too. (eg: going up the Birdsville Track @ 80kph or so). A lot of people will say this is stupid, but I like the sure-footed feeling it gives and it's also safer if you have to brake in an emergency on the gravel. The reason for that is that the front and rear drive shafts have to turn at the same speed. With the vehicle in 4 wheel drive mode (centre diff lock engaged in a full-time 4x4), if you have to hit the skids in a hurry, the front wheels will be less likely to lock up as the rears would have to do so too. In part-time 2 wheel drive this is not the case. It also gives you a better chance at "steering around" a potential catastrophe too.
Just my 2 bob's worth.
Click Image to Enlarge
There's only one thing more painful than learning from experience and that is NOT learning from experience!
Reply 2 of 7
FollowupID: 318873   Submitted: Tuesday, May 04, 2004 at 09:16
Rod W posted:
Contradictory!
FollowUp 1 of 3
FollowupID: 318888   Submitted: Tuesday, May 04, 2004 at 11:31
Member - Roachie (SA) posted:
Rod,
Yeh sorry for the apparent contradiction...it was past my bed time when I wrote all that stuff.
What I meant to add to the 1st sentence was "when you're on the bitumen".
I am a firm believer in using 4WD when I go on gravel roads.
It doesn't really hurt to leave the hubs locked even when driving on the bitumen (as long as the transfer case is still in 2WD); it's just that there may be a minute amount of additional wear and tear on the front drive and an equally minute amount of increased fuel consumption (probably not even measurable).
Sorry for the confusion.
FollowUp 2 of 3
FollowupID: 318979   Submitted: Tuesday, May 04, 2004 at 22:07
Slammin posted:
As above.
Also if you lock them on gravel you will get less chipping and wear on the rear tyres. I can't measure any difference in fuel consumption.
I've also gotta agree on the emergency handling I would rather have a surefooted understeer than a nasty set of fishtails and a rollover. Which is the most common cause of death out here, single car accident ending in a rollover.........
FollowUp 3 of 3
AnswerID: 57119   Submitted: Tuesday, May 04, 2004 at 02:11
GaryInOz (Vic) replied:
Good idea to lock them in occasionally to ensure the grease is evenly spread through your CV/DOJ's. Also allows you to hear any prob's with the front end before you hit the tracks.
Reply 3 of 7
AnswerID: 57131   Submitted: Tuesday, May 04, 2004 at 10:01
Member - JohnR (Vic) replied:
I agree a lot with Gary above to make sure that grease is warmed up and distributed. I have had grease dry out in uni joints and the uni joints give up after you need them next resulting in new uni joints. Has resulted in huge extra costs on top of those of wear.....
I agree with Roachie in the way it is good to lock them in to give a run on some rougher road, just to make sure it all works ready for next time you want it to. I don't know about the surefootedness angle but it just helps the lubricatiion and readiness.
On the way to Gemtree
Who?
Multi famam, conscientiam pauci verentur
Reply 4 of 7
Activities Index
High Rider: Skydive x1, Harley Tour and Seafood x2 High Rider: Skydive x1, Harley Tour and Seafo
Sydney - NSW
This ultimate day experience for one to two people includes: a Harley Davidson return transfer from
Fishing Charter from Nelson Bay Fishing Charter from Nelson Bay
Lower Nth Coast / Newcastle - NSW
Fish the offshore reefs from Stockton Bight to Broughton Island and Seal Rocks, on board our purpose
Sydney Discovery Teambuilder Sydney Discovery Teambuilder
Sydney - NSW
Get your team out of the office and into the fabulous Sydney outdoors on this action-packed, energis
Tasmanian East Coast Tour - 3 Days Tasmanian East Coast Tour - 3 Days
Hobart - TAS
Discover the heritage, history, scenery, wildlife, food and wine of Tasmania's Midlands, Tasman Peni
Book Now - Things To Do
AnswerID: 57242   Submitted: Tuesday, May 04, 2004 at 21:52
Member - Bob L replied:
Agree with Roachie. For outback tracks etc if the surface is loose enough, 4wd certainly maintains stability and helps iron out the corrigations. If the surface is hardpacked then stay in 2wd.
Its like the other chesnut "when to engage low range".
When in the High Country I will regularly use low range (up to say 30KM) just for the addional control and engine breaking especially when exploring new ground.
Bob L
Reply 5 of 7
AnswerID: 57254   Submitted: Tuesday, May 04, 2004 at 22:28
Muzza replied:
I use 4WD when needed but give the hubs a run once a month on GQ (manual hubs)
Reply 6 of 7
AnswerID: 57286   Submitted: Wednesday, May 05, 2004 at 10:25
marklynn replied:
Thanks everyone for the responses...The answers were basically as I had thought
Reply 7 of 7
