AnswerID: 250 Submitted: Wednesday, Mar 07, 2001 at 00:00
Joe McDermott
replied:
Wayne,
It sounds like Steve Hartley has all the answers that anyone might need - his setup certainly exceeds mine ! A pertinent question though might be about your budget. The Tosh that Steve is talking about, configured with all those interfaces, would not see change out of $6,000 and that would be doing it cheaply - it will almost certainly end up at 50% more than that all told.
Another response mentioned using a 12v power source and this may be ideal for you is most of your needs revolve around writing rather than
communications.
As for email up North well most communities will have a line that you can use, even if it is the pubs own phone ! Connection speeds will probably be down from the city, but so long as you are not moving large attachments that should be fine.
One thing you should consider is a backup mechanism - any computer can be temperamental in the heat and dust of the bush and you dont want to lose everything as a result. I am fortunate enough to work in the IT industry and have a couple of laptops available for me to use, but the one I take bush is an old IBM with a 486 DX4 100 processor which does everything I need while I am away from home (albeit slowly, but hey ! whos in a hurry ?) and being stone age seems to survice the dust etc better than anything else.
Call me if you want a chat.
Joe
Reply 3 of 5
