nissan gu rear drive shaft
Submitted: Sunday, May 09, 2004 at 12:43
Kingie
Which way do you fit a rear drive shaft - is it the slip end to transfer box or the other way? (Meaning the thin end lowest and the fat end highest?)
Reply By: Truckster (Vic) - Sunday, May 09, 2004 at 12:48
Should be slip to the front if I remember...
57827
Follow Up By: Kingie - Sunday, May 09, 2004 at 15:21
Wrong
mine is to the rear
319597
Follow Up By: Kingie - Sunday, May 09, 2004 at 15:22
Have you got a gu if so have a look under for me
319598
Reply By: brian - Sunday, May 09, 2004 at 16:18
Checked my gu slip end is definately at rear not near transfer case.Not as truckster says
57851
Follow Up By: Nino & Kerry (VIC) - Sunday, May 09, 2004 at 20:36
Hi all,
just went outside and checked
mine. Just as Brian said, slip to the rear.On the front its slip to the transfer case.
Nino.
319644
