Ericsson R290 Satellite Phone Questions
Submitted: Monday, May 10, 2004 at 21:31
ThreadID: 12767 Views:4678 Replies:4 FollowUps:0
Hi fellow R290 owners,
I just received my R290 from *e1* on Ebay and after wasting 3-4 hours trying to get it to work in satellite mode, it now makes & receives sat calls.
However I think there may be a problem with the charging system or the batteries may be suspect, so I have a cvouple of questions I am hoping you can answer in order to isolate the problem.
1. Does the phone power up without the battery if the mains charger is plugged in and turned on ?
2. If the battery is full, does the phone indicate via display message that the battery is full ?
3. Any other quirky charging tips ?
Phil P
Reply By: Hedonist - Monday, May 10, 2004 at 23:16
Phil,
It sounds as though you do not have the manual - download it from *EI*'s website. It should answer all your questions.
I think mine operates OK with the charger plugged in - if you think the charger is dicky try the 12V one.
Pete
AnswerID: 58098
Reply By: Peter McGuckian - Tuesday, May 11, 2004 at 09:29
The phone will work with the charger attached. Battery life isn't great so not worth leaving on for a long time unless attached to the charger. 12v charger will really only work when driving - needs >14v to charge the phone, I think. Phone light blinks slower when charging has stopped.
Well worth downloading the manual.
AnswerID: 58124
Reply By: Brad - Tuesday, May 11, 2004 at 19:50
Off topic, but I had to get Globalstar to change the 'SIM Centre' setting to get the r290 to send SMS text. Suggest you check this before "heading out".
Brad.
AnswerID: 58214
Reply By: Phil P - Tuesday, May 11, 2004 at 21:52
The problem with my phone is not that I don't have instructions but both my chargers have faulty cables. If you bend them a certain way then the phone charges !
It will be interesting to see how the warranty issues are covered !
Thanks for the tip with the SMS !
AnswerID: 58240
