damaged vehicle auctions
Submitted: Wednesday, May 12, 2004 at 09:27
ThreadID: 12806 Views:3126 Replies:3 FollowUps:0
Gday all,
My 89 Cruiser motor needs replacing (2H), I was wondering about the damaged auctions, and about picking up a damaged vehicle ie a later model say a 1HZ model and replacing the running gear over to my cruiser, what sort of money do cruisers pull at these auctions? is this a viable option? I could use some of the other bits ie door trims and such as well.
Thanks in advance
Reply By: Truckster (Vic) - Wednesday, May 12, 2004 at 14:14
All depends on the amount of damage.
Wreckers are usually a large buyer of these, so you may have to battle for them..
AnswerID: 58317
Reply By: Outnabout David (SA) - Wednesday, May 12, 2004 at 14:52
Choppa,
You can get a brand new genuine motor for 7-8K which would be cheaper than buying a wreck with probably the same mileage on the motor. If the old engine has lasted since 89 then you would get another 15 years trouble free from the new one.
AnswerID: 58322
Reply By: Member - Pesty (SA) - Wednesday, May 12, 2004 at 16:17
Choppa you cheapest option is to rebuild yours espectially if you can do the remove and replace. I did mine 2 years ago and the rebuild of the motor to 3/4 stage was $2500, and the head full rebuild was $600, Plus I rebuilt injectors and new clutch and bits and pieces less than $4 big ones . The swap for a 1hz is not easy as they are totally different.
The only other option is a second hand 2h, or 12ht which are hard to come by.
AnswerID: 58331
