Hilux 2.4 deisel oil pressure problem
Submitted: Thursday, May 13, 2004 at 13:51
Member - Pesty (SA)
Hi all I have a hilux 2.4 deisel which has done 54,000 since Southcotts reco motor and has started blowing oil filter seals (3 in last couple of months and 2 in the last fortnight) apparently a common problem, is there a easy fix or is it a motor out job and replace pressure relief valve.
Reply By: Cruiser88 - Thursday, May 13, 2004 at 21:17
Hi Pesty
Have no idea about your Luxie but when you have a 60 series why go backwards. love the photo but you could have put a big load on it. We moved from Gympie to
Winton and on the last load couldn't fit hieght wise under the awning at
Augathella roadhouse and the 60 handled it beautifully (can't go past the the HT12). Went bu8sh recently and a mates Turbo Surf (read Hilux) just could not cut it. Look forward to swapping hints.
58512
Reply By: Member - Roachie (SA) - Thursday, May 13, 2004 at 22:06
Pesty,
Yes; there is an easy fix....but you're not gunna like it.
BUY A NISSAN...!!!!!!
lololol
58525
Follow Up By: Member - Pesty (SA) - Thursday, May 13, 2004 at 22:52
You just concentrate on getting that rubber band wound up extra tight if you think a nissan is going to get to the old country and back in a long weekend. Allow plenty of time there for winding to get home.
320241
Reply By: B3 - Sunday, May 16, 2004 at 07:27
Repair of the pressure relief valve only requires you to remove the oil cooler assembly and not the motor....not an overly difficult job from memory.....
58766
Follow Up By: Member - Pesty (SA) - Sunday, May 16, 2004 at 20:00
Thanks B3 i removed the oil filter and located the 2 relief valve heads and removed them and the pistons dont think these were replaced at rebuild.
Have you had any exp. with them do you need a new oil cooler body or do they
bore them out
320503
Reply By: B3 - Monday, May 17, 2004 at 17:55
Hi again Pesty
Yes, I had to do
mine not long after I bought it (second hand) about 8 years ago. I found that the spring assembly was all gunked up so seems the previous owner hadn't been very good with oil changes, etc.
The Toyota manual says that if you coat the valve with engine oil then it should fall smoothly into the housing under its own weight (hold oil filter bracket upside down for test). If it doesn't they recommend replacing valve and/or oil filter bracket.
Hope this fixes it! My pressure problem now is due to excessive blow past the pistons....am getting a rebuilt motor on Friday...
Ben
58941
