Firestone Coil-rites
Submitted: Friday, May 14, 2004 at 22:25
Member - Cruisin (QLD)
Hi all
Just got the Cruiser installed with some rear Firestone Coil Air bags. I must say they have improved the handling by a fair bit. With the bags at 15 PSI, I would say body roll has been reduced by 30% when cornering. This is for an unloaded vehicle except the Long range fuel and
water tank are full. Theres 180kg just there. You cant hide the fact that the vehicle is still big and heavy (2750kg) but it is certainly an improvement.
Cheers cruisin
Reply By: Andrew & Jen (Melb) - Friday, May 14, 2004 at 23:26
I have Polyairs on
mine and they have made a good bit of difference, I agree. Did you get yours through Truckspring in the US? Do you know how much the rear Kaymar bars weigh as they are pretty solid.
58674
Reply By: Eric from Cape York Connections - Saturday, May 15, 2004 at 06:57
I also have the poly bags and cant fault them they have done about 200,000 k now
So i think the bags you have should give the same results.
All the best
Eric
58688
