GQ patrol oil light/preassure gauge
Submitted: Sunday, May 16, 2004 at 15:18
Pauly
G'day all i went on a short trip on the weekend and going through mud and big puddles i noticed that my oil light was on and my oil gauge was reading just befor max when idling neither changed at higher revs.Do both sensors work of each other or are they both seperate, oil level is ok so i am a little confusedcan one of the sensors be faulty or is a bigger problem than i think it is.At the moment the preassure gauge is reading as normal but the oil light is still on and some times go off or just fade away or just stay on.
Any thoughts or info would be much appreciated
cheers paul
Reply By: Kiwi Ray - Sunday, May 16, 2004 at 16:28
Hi Paul
The gauge and light use the same sensor unit.
These are known to give problems, and a new unit usually fixes the problem.
Also while the sensor is out fit a test gauge to the port for a good reference.
Hope this helps
Ray
58802
Reply By: Truckster (Vic) - Monday, May 17, 2004 at 13:56
They have a habit of dying when they get full of shiat.. you can WD40 it or just replace it, nissan have an upgraded one now.
58911
