Bypass Adelaide
Submitted: Thursday, Jul 30, 2015 at 18:39
Mazzy1
I have regularly driven from Victoria to
Darwin but this time I will be towing the van and don't want to drive the
Adelaide hills is it best to turn at
Murray bridge to miss the
Adelaide. I have towed the van to
Cape York last year so I have no problems with towing but just won't to miss
Adelaide any comments would be helpful
Thanks Mazzy1
Reply By: Member - Bigred13 - Thursday, Jul 30, 2015 at 19:22
Hi Mazzy1 ,yes If you turn right at
Murray Bridge ,via Palmer,Mt pleasant,
Gawler and then via
Two wells to the national highway 1 you will avoid the
Adelaide hills.There is a large
hill at Palmer ,but it is a good run ,by the way up near Palmer
hill ,keep an eye out for the polar bear on the right near the top ,very good scenery that way too .
588133
Reply By: Mazzy1 - Thursday, Jul 30, 2015 at 19:32
Thanks bigred13 I will go that way it is so cold here in
Ballarat the polar bears may come to life
588134
Reply By: Colcam42 - Thursday, Jul 30, 2015 at 20:06
Hi Mazzy, we live in the mid north of SA and come back from Victoria, (
Melbourne) via
Mildura, The Riverland,
Renmark,
Morgan,
Burra,
Spalding and then the choice of going via
Wilmington (
Horrocks Pass) or
Quorn (Pitchi-Ritchi Pass) to Pt
Augusta. Alternatively via
Crystal Brook, Pt Pirie bit further south. A nice drive, different things to do and see for a change, the Lower
Flinders Ranges are worth seeing/exploring if you have the time. The easiest with the van is to go via
Crystal Brook but the two Passes are ok if not a bit winding downhill, nothing that you probably would have already done in Victoria. Truckies heading East use the
Crystal Brook-
Spalding-
Burra-
Morgan-
Renmark route but not in any number. I drag a 28ft 5th Wheeler via the
Crystal Brook route because it is the direct way to Pt Pirie. Free camps along the way.
Have a great trip.
588137
Follow Up By: Colcam42 - Thursday, Jul 30, 2015 at 20:10
Hi again, should have said, we use the Sunrasia Highway from
Ballarat to
Mildura, a nice trip on it's own.
Col
856213
Follow Up By: Mick O - Thursday, Jul 30, 2015 at 22:47
Second this route from Col. I use the crystal Brooke route to avoid Horrock's pass.
Just be aware that you'll be stopped at the quarantine inspection point at Yamba just before
Renmark so don't have any fruit/vegies on board. I always stock up at Pt
Augusta before heading on up the Stuart.
Safe Travels,
Mick
856217
Reply By: Member - Stephen L (Clare SA) - Thursday, Jul 30, 2015 at 20:12
Hi Mazzy
There are a number of ways that you can detour
Adelaide. If you want to make up time, from
Murray Bridge, head for Palmer,
Springton,
Nuriootpa and
Kapunda.
From
Kapunda you can either head for
Tarlee, then up through
Clare, then north to
Port Augusta. If you do not want to go through
Tarlee, a lot flatter way is
Kapunda,
Eudunda,
Saddleworth. From
Saddleworth, you can either go through to Auburn then
Clare, or straight up to
Burra, through to
Spalding,
Gulnare, then either North to
Port Augusta via
Melrose, or head for highway 1 via
Crystal Brook.
588139
Reply By: Mazzy1 - Thursday, Jul 30, 2015 at 20:15
Hi colcan 42 I have often gone via
Mildura to
Renmark with work .will not have time to stop at flinders Rangers this trip as I only have a week to be in
Darwin for a family gathering .but will then meander down the wa coast for a couple of months on the way
home thanks for your suggestions
588140
Reply By: Mazzy1 - Thursday, Jul 30, 2015 at 20:28
Hi Stephen L
Thanks for your. Reply it seems that turning of at
Murray bridge is the way to go
588143
Reply By: Sigmund - Friday, Jul 31, 2015 at 09:29
IME the Calder to Melb is the quickest not least cos much of it is 110 limited, not 100, and you miss the big country towns.
There's a way of avoiding
Mildura that's east of
Renmark by turning south around L Cullulleraine and then east to
Red Cliffs. Avoids a good deal of slowish traffic.
588161
Follow Up By: Member - rooster350 - Friday, Jul 31, 2015 at 10:06
Sigmund, he is going the other way...north, and the Calder is not much good to him as he is leaving from Balllarat, that is west of the Calder
856229
Reply By: Member - wicket - Friday, Jul 31, 2015 at 11:31
Must say I'm a bit confused here, in your original post you say you don't want to drive the
Adelaide hills and then posters encourage you to go through the
Adelaide hills via Palmer
Springton etc,
well these are the
Adelaide hills and it would be much more of an ask to drive on these windy hilly roads towing a big caravan than coming straight up the freeway.
Are you trying to miss
Adelaide or the hills?
588171
Follow Up By: dean ( SA ) - Friday, Jul 31, 2015 at 12:17
Yes I thought it odd to send someone through Palmer but couldn't be bothered asking why.
856239
Follow Up By: Member - rooster350 - Friday, Jul 31, 2015 at 13:25
We went through
Adelaide via the freeway earlier this year and it was a very easy run, probably quicker than the other ways suggested.
856246
Reply By: Mazzy1 - Friday, Jul 31, 2015 at 18:41
Thanks for all your replys the main reason that I was going to miss
Adelaide was to make up some time as I have a tight schedule to be in
Darwin .years ago it was a 3 day drive for me in car only but we tend to slow down as we age
588183
Reply By: Member - Andrew & Jen - Friday, Jul 31, 2015 at 20:57
Mazzy 1
As a local who uses all the roads mentioned, I would still take the metro route by choice, albeit avoiding peak hours, as it would be close to the quickest and certainly the smoothest with a van.
Straight in on the SE Freeway (100 kph), turn half right along Portrush Road, cut across to Hampstead Road until Regency Road - all on the A17 - then left on Regency Road and right on to Main North Road (A1) - all 60 kph and then take the
Port Wakefield Road north to Pt
Augusta, starting with 70, then 90 and soon 110 kph, the first 100 kms on a divided hwy and after that most, but not all, towns bypassed.
In fact just used it today coming back from being up north as I needed to take the smoothest road
home as I was nursing a broken main leaf on the LHS of the van.
588189
Follow Up By: slave - Saturday, Aug 01, 2015 at 16:10
I would have to agree with Andrew and Jen.
It so easy to drive through
Adelaide as long as peak hour is avoided, even then its like
Melbourne on a normal day.
856275
Reply By: Mazzy1 - Friday, Jul 31, 2015 at 23:51
Thanks Andrew and Jen
I will be leaving
Ballarat in the morning and see as to what time we will be going throug
Adelaide.
The only time I have had any trouble with city's was in
Sydney a few years ago when I missed a turn
Regards mazzy1
588196
