Dash Pod for GU Patrol
Submitted: Tuesday, May 18, 2004 at 10:22
ThreadID: 12966 Views:2687 Replies:5 FollowUps:6
Hi One and All
Have searched high and low and actually came up with a post from Truckster (who I cannot find on the member list anymore) back in April 03 showing pics of dash pods for the GU Patrol. Would anyone know where in Melbourne these can be obtained? I want to fit a Uniden UH088 into the beast but running short of room (sunroof fitted)
Cheers in advance
Reply By: Member - Roachie (SA) - Tuesday, May 18, 2004 at 10:34
David,
I got mine from a Sydney company....The Dept of the Interior.
I know that's not in Melbourne. I was living in Cooma NSW at that time and I sent them my UHF radio, the external speaker, a voltmeter and switch (so I can switch the meter between batteries). I also drew a neat diagram of how I wanted everything mounted in the pod. I also did as much of the wiring of the voltmeter and switch beforehand.
They sent back the new pod ready to instal......no holes to be drilled. Works a treat and have been over some BAD-ASS corrogated roads (Cape York etc) and it never moves at all.
Highly recommended.
AnswerID: 59051
Follow Up By: Member - Sam (NSW) - Tuesday, May 18, 2004 at 11:12
check out www.consoles.com
FollowupID: 320692
Follow Up By: Truckster (Vic) - Tuesday, May 18, 2004 at 11:26
yea thats the place.
Any 4wd store can get them in for you or you can deal direct with them.
There was one on ebay yesterday might still be up there
FollowupID: 320695
Follow Up By: Leroy - Tuesday, May 18, 2004 at 11:49
I think you can get them through Time Plus Communications in Brunswick.
Leroy
FollowupID: 320702
Follow Up By: Member - David M (VIC) - Tuesday, May 18, 2004 at 16:21
Thanks guys, information received and noted. Thanks for the quick and informative responses.
David
FollowupID: 320734
Reply By: Michael - Tuesday, May 18, 2004 at 11:31
Hi there, I double-sided taped my 27meg unit, which is rather large, to the top of the dash in the same spot as it would sit with the pod in my last GU. It sat there for 4 years and have just done the same for my latest GU. The pod just makes it harder to see over!!! Regards Michael
AnswerID: 59059
Reply By: duncs - Tuesday, May 18, 2004 at 22:02
David,
The Department of the Interior are on the Princess Highway, Kogarah Bay. In Sydney they are very, very good but not cheap.
I upgraded the sound system in the GU and used the space left in the dash to mount the UHF. Simple, cheap and very neat. Plus the 10 stacker makes it easy to carry plenty of music.
Duncs.
AnswerID: 59177
Follow Up By: Michael - Wednesday, May 19, 2004 at 08:06
Hi Duncs, When you replaced the stereo, what about the wiring, is it the same for the new unit or modification necessary to the wiring.. Michael
FollowupID: 320843
Follow Up By: duncs - Wednesday, May 19, 2004 at 20:50
Michael,
Me and electronics don't get on all that well, coupled with the facts that I had just spent $50000 on a new car and I was really strapped for time I had it done professionally. I was told that they make up a set of plugs so that the original unit can simply be plugged in to it's original connections if you ever desire it. They also installed the UHF looks and works great and cost about $160. I don't regret it one bit.
Duncs
FollowupID: 320958
Reply By: Cobra - Tuesday, May 18, 2004 at 22:43
David,
I have a dashpod from the Dept of Interior with a UH088 radio. Just rang them, told them what radio had to go in and they sent it out. Very simple to fit yourself and works a treat. Has not restricted frontal vision to any extent
AnswerID: 59190
Reply By: rolande- Tuesday, May 18, 2004 at 22:47
David,
Time Plus Communications in Brunswick as mentioned above, excellent customer service
Rolande
AnswerID: 59191
