trader ad update
Submitted: Tuesday, May 18, 2004 at 17:46
Member - Paul H
Probably a dumb question, but can someone tell me how to update my trader ad.
ie; sell price. Been mucking around for a while, can anyone help
PMK
Reply By: Member - Roachie (SA) - Tuesday, May 18, 2004 at 17:54
Paul,
I had the same problem and ended up having to get David (EO) to change it for me. You're supposed to be able to go to the ad, click on the "SEND ENQUIRY" button associated with the ad' and you'll get an email advising that somebody wants to know something about your stuff. It will ask you a question in that email; something like "WOULD YOU LIKE TO AMEND YOUR AD OR MARK IT AS SOLD". You're then supposed to click on that option and go in and make the changes to the ad'.
Give it a try.
Good luck
59119
Follow Up By: Member - Paul H - Tuesday, May 18, 2004 at 18:30
Roachie,
Thanks for the info,you were right. Send yourself an enquiry, then update yor ad.
Thanks again
PMK
320768
Reply By: Topcat (WA) - Tuesday, May 18, 2004 at 18:50
Hi Paul, when you initially posted your trader ad, there should have been sent to you an email from ExplorOz confirming the ad & also an ExplorOz web address which allows you to update your ad. I had a problem like yours on previous trader ads a while ago & to solve the problem, David is giving you the address for the updates. Corrrect me if I'm wrong David but that is what is happening when I now post an ad. Cheers.
59129
Follow Up By: Member - Paul H - Tuesday, May 18, 2004 at 18:56
The ad has been in for a while & I had deleted the confirmation. Come to think of it, I had used it to alter my ad not long after origionally postiing it.
Thanks for your input,
PMK
320773
