Monday, Aug 31, 2015 at 18:01
Congrats on your new purchase.
Our batteries remain as per factory installation and we haven't had any problems. Ours is a 2006, same as your model. Awesome vehicle :).
Yes, both cranking batteries, however one battery alone will crank the car by itself if the other has "died"
We have had ours from new.
My husband is mechanically minded and was also concerned by the pairing of the batteries the way they are.
The only time we ran out of
battery power was before we had portable solar panels. We were stuck on a dune for 5 nights, after it rained for 24 hours. We charged the car each day, by running it for a while...not ideal. But it did work. LOL..you should have seen the black plume of smoke that came out of the exhaust when we eventually moved off the dune when the roads opened again!
All the accessories etc.... still run fine on the one battery too, should you only have the use of one...we have done it after 1 battery "died" on a recent trip away.
Yes..you can isolate them with a manual switch.
We do carry a battery pack which is fixed (removable if you want to).. to the inside (back) of the car and has several plugs(merit)which we use for the fridge, phone chargers, laptop chargers as
It is charged by both/ either when driving, or charged by solar panels when we are stopped for an extended period.
It can be used to crank the car in the event of something disastrous happening and your cranking batteries just won't do it :(.
It is very useful as it is portable and a multi purpose unit. It is like carrying a 3rd battery around and is heavy. We also use it to power an air compressor for inflating either the car or TVan & caravan.
Merit plugs(especially for your fridge) are very good as they will not work their way out, like a cigarette lighter plug will. It has happened to us. The connections are an easy change over.
We also have Anderson plug connections in the battery pack to both charge the batteries by solar panels and connect to the caravan too.
Home of 12 Volt..portable battery packs
Here's the link to their site.
They are expensive, however can be a lifesaver too.
It gives you so many more charging options too. We have ours in the car whenever we go camping or caravanning as it gives us another power source.
You don't have to have such a big one, but as long as it will crank the car...it is a very worthwhile investment.
Hope that helps/ gives you an idea for a different option.
Robyn
589838
