Tuesday, Sep 22, 2015 at 15:37
Hi Keith,
I have two x 135 w flat direct stick panels feeding into two x 90 ah LiFe Po 4 batteries. I have a battery computer unit that calculates state of charge using a shunt.
The van is a full ensuite 19' Crusader. The system has to run various LEDs, 60 l Waeco fridge, TV, sound system, iPhone, iPad charging etc.
The only 240 v appliance we run is the washing machine and for this I have installed a 700 w inverter.
In terms of performance, I have never seen the SoC below 50 %. And that was after four days of rain in Tassie. Our normal use is down to 85% after a single night and that returns to 100% before midday.
The mains charger remains off even when in caravan parks as it gets enough from the
solar system and the manual for the batteries says not to trickle charge them.
The only bit missing from my puzzle is that I don't use the Anderson plug to charge the van batteries from the alternator as I haven't worked out whether there is a need to have some sort of isolator between the alternator and the panels.
I purchased the panels, controller and computer from Solar4RVs and the batteries from Evworks.
When looking at price, they are currently listed at $675 for a 90 ah battery, you need to remember that they weigh half as much, can handle many times more cycles and can be discharged down to 20% SoC without harm.
Now the usual disclaimers -no connection to the firms mentioned. I'm a user not a techo and don't want to be dazzled by the Internet experts.
Hope this helps.
Skull
858623
