Monday, Oct 12, 2015 at 20:08
G'day Gazza,
It depends largely on the size of the van you need and what your budget is.
For a good quality mid sized pop top van (which won't take a lot of setting up) I believe you should be looking at The Goldstream (Vic) or Coromal (WA) brands of vans.
We chose a Goldstream Vacationer when we upgraded from our previous Camper Trailer.
This unit is a "wind up" style where you pull the beds out each end, to end up with a large living area inside. We liked this style because of the flexibility of two queens size beds, plus the table converting to another double bed, which suited our future idea of taking the grand kids (one at present) away with us.
This model has a low profile when towing and fitted under the enclosed carport without the need to modify anything and seats six around the table if eating inside.
If there is only the two of you, a pop top van keeps the profile reasonably low but you "sacrifice" living space as the queen size or twin bed options are internal to the overall length.
Again, the Goldstream and Coromal brands have excellent reputations which are perhaps a level above the more "budget" oriented, but popular Jayco brand of van.
There are several other brands around and it is probably a matter of deciding on the size of the van you want and the features they have, then visit some dealers to help narrow your choice.
The chances are when choosing a "pre-loved" van, most if not all "problem areas" have been sorted by the previous owners, but beware of that occasional "lemon".
Just as an example, I bought our van brand new to order and therefore have the options available to suit our lifestyle. Even though it is an excellent product, I have modified two "problem" areas I didn't like. The
water tank breather system was not quite designed to my liking and I have added a separate breather hose out the back, which has fixed the
water supply problem. I now can both fill the tank quickly and draw the water out of the holding tank, without experiencing water flow problems due to a positive pressure that restricted flow.
Another "problem" I had, was the inability of the sink draining in a reasonable matter, as the outlet hose traversed across the other side of the van before the downward outlet and waste water was retained in the "undulations" of the pipe run across to the other side. A simple fix was to reroute the outlet pipe back to the sink side of the van and add a right angle elbow to the shortened pipe run, which has fixed the problem.
These "problems" where easy to fix (for me at least) and hopefully buying a pre-owned van, all of the similar encountered problems, (regardless of the brand) have had them sorted out.
I have a good mate who has invested in a big hi-end, off-road
caravan, with all the bells and whistles, including an on-board shower and
toilet and even a washing machine.
When we were invited to view his new "mobile house", the first thing we thought was that it was designed as two person accommodation only. The two big upholstered chairs either side of the "dining" table left no room for any other "guests" to sit down and "chew the fat."
Their choice of course, but the features didn't tick any of our boxes for mobile accommodation.
They are good friends but hell, when one decides that the on-board
toilet is only for "number ones" we think they have lost the plot somewhere:-)
We can choose to leave our porta-potti inside the van, (if there is just the two of us) or put it in a pop up tent if
bush camping. As for showers, again the pop up tent is enployed, unless we are in a
caravan park, where the park facilities are employed.
Good luck with your quest. You will find that regardless of your choice of van and the features you include to narrow that search, you will end up with a compromise of some sort or another.
591513
