AnswerID: 4357 Submitted: Friday, Jun 21, 2002 at 00:00
Derek Jarrett
replied:
Hi Kieth. On the recommendation of a
Brisbane exhaust
shop, I had fitted 'Motivator' extractors, a Mercury muffler and a 2.5 inch system to my 80 series 1HZ and found the following
1) acceleration improved slightly
2) the engine sounded less asthmatic
3) torque improved significantly
As a result I can hold an extra gear on hills which makes the car a whole lot more driveable especially when towing. I'm also using a Finer Filter.
Toyota rate the engine at 96 kw and I recently recorded 87Bhp on a rolling dynamometer. I don't know how this compares to other cars, but the dyno guy said it was the most power he'd registered for a 1HZ with these modifications. This all cost me $600 and I reckon it was worth it. If you are considering a turbo you will have to ask yourself, are you going to get $2500 worth more power? The engine rebuilder I use claims the 1hz is the worst engine for turbo charging that Toyota have ever made. Hope this helps you and doesn't offend anyone else.
Reply 6 of 6
