Thanks for the 17 responses on the Fridges
Submitted: Saturday, May 22, 2004 at 17:13
ThreadID: 13077 Views:2199 Replies:6 FollowUps:7
I really appreciate the no holds attack on the so called sacred cows of 4wd marketing, that clouds the judgement. And all the other miscellaneous info.
Reply By: Lone Wolf - Saturday, May 22, 2004 at 17:46
So.......... when are you going to buy the Waeco????????
AnswerID: 59703
Follow Up By: funnyone - Sunday, May 23, 2004 at 10:14
Just one more thought
MAX AMP DRAW ENGEL 40L AND SMALLER 2.5A P/H
MAX AMP DRAW WAECO 50L AND SMALLER 5.7A P/H
MAX AMP DRAW ENGEL 60L AND LARGER 4.5A P/H
MAX AMP DRAW WAECO 60L AND LARGER 6.6A P/H
I HAVE DONE A BIT OF RESEARCH BEFORE PURCHASING A FRIDGE MYSELF, AMP DRAW WAS VERY IMPORTANT FOR ME AS I USE A SOLAR PANEL TO CHARGE BATTERIES AS I STAY IN ONE LONGER THAN MY BATTRIES CAN LAST , JUST A THOUGHT.
FollowupID: 321361
Follow Up By: Lone Wolf - Sunday, May 23, 2004 at 18:16
Hmmmmmm......
Can't and won't dispute that.
My Waeco CF 35 draws 3.1 Amps over 12 volts. Book running time is 17%..... can't confirm that part though.
FollowupID: 321407
Follow Up By: Crackles - Monday, May 24, 2004 at 22:30
Sorry Funnyone but a low current draw doesn't mean it uses less power over an hour. Even though the 40 L Engel may only use 2.5 amps, you will find that it needs to run almost twice as long as a fridge that has better insulation to keep it at the same temp. As an example: An Autofridge may have a current draw of 3.5 amps but at the end of the day it will have only run half the time of the Engel, effectivly using 30 % less power.
The single most important feature of a fridge is it's insulation & both Waeco & Engel (amoung others) chose not to put enough in.
Craig............
FollowupID: 321600
Follow Up By: funnyone - Tuesday, May 25, 2004 at 08:40
Thanks for your response you are very true , just could not afford a autofridge .
FollowupID: 321620
Reply By: Member - Allan Mac (VIC) - Saturday, May 22, 2004 at 17:57
so........ when are you going to buy the Engel??
AnswerID: 59705
Follow Up By: Lone Wolf - Saturday, May 22, 2004 at 18:16
Silly Buggar!!! He meant to say WAECO!!
FollowupID: 321296
Reply By: Brian - Saturday, May 22, 2004 at 18:00
so........ when are you going to buy the Auto fridge ??
Brian
AnswerID: 59706
FollowupID: 321297
Reply By: Member - StevenL - Saturday, May 22, 2004 at 19:51
Guess I had better weigh in for Waeco and save the Wolf some typing!
CF40 has performed flawlessly over last 10 months.
Steven
AnswerID: 59715
Follow Up By: Member - Allan Mac (VIC) - Saturday, May 22, 2004 at 19:55
Wolf is the silly old bugger ..wasting all those letters typing. Think of all the 1's & 0's now floating around cyber space gone to waste. :-)
FollowupID: 321310
Reply By: Member - Toonfish - Saturday, May 22, 2004 at 23:20
Waeco is all good again with me have the new lid and also my engel frifge straps !
all i need is time off and some beverages for the fridge to fill with
AnswerID: 59736
Reply By: Davoe - Sunday, May 23, 2004 at 17:51
I like this quote "the debate will continue to rage because there is no clear winner"
Id go an engal personally but only cause I have witnessed them "do the job"
AnswerID: 59804
