Supreme Territory prewired <span class="highlight">solar</span> wire location
Submitted: Monday, Nov 02, 2015 at 19:21
SuperGrover
I have a 2007 Supreme Territory which was prewired for
solar with 2 small
junction boxes on the roof each with a set of brown and white wires of about 4mm. I did not buy this van from new.These wires do not currently have any power on them. Does anyone know where the other end of these wires terminate or are hidden. I am considering fixing
solar panels to the roof and these would be handy. The wires are not visible where the battery box, fuses and other electical items are which is where I would have expected them to be.
Reply By: mike39 - Tuesday, Nov 03, 2015 at 07:17
They are probably wired parallel into the aux. charging inputs from the vehicle.
Check to see if there is voltage at those boxes.
mike
592293
Follow Up By: SuperGrover - Tuesday, Nov 03, 2015 at 22:46
I thought the same but no power and separate pairs of wires not looped either
860475
Reply By: Racey - Wednesday, Nov 04, 2015 at 08:53
Hi Supergrover, I suspect behind the panel with othe controls and water guages; give Supreme a call I'm they could help.
592325
Follow Up By: SuperGrover - Wednesday, Nov 04, 2015 at 23:49
I cannot see the wires behind the cd/radio which is where I fitted the water gauges . I also emailed Supreme a couple of years ago with no reply and have emailed them again 2 days ago with my chassis number etc but still no reply again. Thanks
860529
