79 series aluminum canopy.
Submitted: Monday, Nov 23, 2015 at 17:59
blue one
Hello there,
Having a bit of trouble here with finding a canopy to bolt onto a 79 series dual cab chassis.
I am after a aluminum canopy with two doors, a floor and captive nuts to secure unistrut when required for roof racks.
The canopy would have the door seals recessed and not exposed.
Any help would be appreciated and it would be preferable if the manufacturer is on the Central Coast of NSW or Hornsby area.
Steve
Reply By: The Landy - Monday, Nov 23, 2015 at 18:25
The Landy
The Landy
The Landy
I will unashamedly “plug” Dave Vella at Dave’s Metal Products, Wetherill Park in
Sydney.
Dave made the canopy on my current vehicle and one previously for an earlier vehicle we had. The current one has done 60,000klm and the earlier vehicle closer to 100,000k and I have never had any issues, no dust or water ingression.
Dave’s is a quality product that won’t be able to compete on price with cheaper imports, but you don’t want it to fall apart and rest assured the workmanship is first class.
Some more in my blog you can take a look at…
Modifications and Upgrades - Toyota 79 Series Dual Cab
Cheers, Baz – The Landy
593039
Follow Up By: blue one - Monday, Nov 23, 2015 at 18:28
Thanks Baz
Looks pretty much of what I'm after
861224
Reply By: Notso - Monday, Nov 23, 2015 at 18:27
It would probably be a one off build.
This mob is in
Cairns but will ship it anywhere.
Norweld
593040
Follow Up By: blue one - Monday, Nov 23, 2015 at 18:32
I was up there for 2 years and liked the canopies they did.
Missus worked across the road which gave me time to have a look.
I will take another look at them as I thought the transport would be a killer, but you never know.
Ta
861225
Reply By: Frank P (NSW) - Monday, Nov 23, 2015 at 18:52
Hi Steve,
It would be very difficult to go past
CSM in Brisbane for quality.
I have one on my BT50 dual cab. Absolutely dust and waterproof, central locking integrated with the vehicle system, door not locked alarm, internal lighting, full length
trundle drawer underneath if you want it.... the list goes on.
Like Baz's, it won't compete on price with cheapies, but it will be difficult to find better. Advantage of this one is it has no lip to the doors, so you don't lose space by having to install a false floor to allow drawers and fridge slides to slide out.
Cannot recommend them highly enough.
593041
Reply By: rumpig - Monday, Nov 23, 2015 at 19:10
I had
The Box Thing here in
Brisbane build
mine for me, though they also have a
Sydney dealership aswell i believe. As previous posters have said, price won't compete with cheaper versions, but it was built to my specifications exactly how i wanted it. Canopy has insulation between the inner and outer skins, and price depends on what you want to add to it obviously. The racks on
mine can be removed as you want, there's holes the whole lenght along where they are located on that allow the racks to be positioned where you want them.
593042
Follow Up By: blue one - Sunday, Nov 29, 2015 at 15:21
Looks like an excellent set up. What GVM upgrade did you get?
861442
Follow Up By: rumpig - Sunday, Nov 29, 2015 at 16:41
I had a Carrolls 3760kg upgrade done on it blue one
861444
Follow Up By: Gramps - Sunday, Nov 29, 2015 at 17:30
rumpig,
Just a couple of questions if I may
1. Is the canopy bolted directly on to the chassis without the need for a tray ?
2. Is the opened box in the last
pic a lockable unit ?
861446
Follow Up By: blue one - Sunday, Nov 29, 2015 at 17:58
Thanks for that
861447
Follow Up By: blue one - Sunday, Nov 29, 2015 at 18:09
Rumpig,
If it is not too much trouble can you advise length from front bull bar to rear of canopy and the height not taking into account the roof racks.
I have garage trouble.
Steve
861448
Follow Up By: rumpig - Sunday, Nov 29, 2015 at 20:02
Hi Gramps....yes the canopy is bolted to the chassis, i purchased the vehicle new without a tray. The open box inside the canopy isn't lockable, but there's no reason i couldn't of gotten it made that way if i wanted it so (all outer boxes have locks on them...ie:- behind the wheeels and under the tray also). Both outer doors on the main canopy have locks on them, so i didn't see the need for an internal box to have a lock on it also. Cheers
Hi blue one....length of vehicle from bullbar to back of canopy is about 5450mm, if you fit a towbar then add about 150mm to that length again if kept in position. Keep in mind the canopy i had made at 1700mm long to try and help reduce rear overhang length a touch, so it's not the same as an1800mm long tray would be. Height wise....without the carry racks fitted the top of canopy is about 2050mm high, with the carry racks fitted add another 100mm to that height. I have just fitted an alloy Rhino Rack tradies roofrack on the vehicles roof area, and that comes in at about 2250mm overall height of my vehicle now with the sides that it has (you can get those without the sides as a platform only set up. The Carrolls GVM upgrade probably gives closer to a 3" lift in
suspension height of the vehicle to my knowledge, there are other GVM upgrades that give a lower
suspension lift height i believe.
861449
Follow Up By: blue one - Sunday, Nov 29, 2015 at 20:42
Legend thanks
861450
Reply By: Supersi - Monday, Nov 23, 2015 at 20:26
Just had a canopy built by Concept Canopies in
Brisbane. Very good build quality and happy to recommend them.
593048
Reply By: Bob Y. - Qld - Monday, Nov 23, 2015 at 20:47
While Baz's recommendation might be the best financially for you, I would do as much research, from other fabricators and owners, to get the most practical end result.
We've had an aluminium slide-on from Top Form Campers for almost 3 years, and I still see "ideas/mods" that I'd like on ours. Even using alloy, weight will be an issue, so choose your add-ons wisely.
Top Form was bought out by a
young bloke and he calls it Dynamic Engineering & Fabrication now. They are in
Hervey Bay Qld.
Check here
Metalink are another in
Brisbane area. See
here
See a lot of canopies made from chequer plate. Looks good, but I'd question just how easy they would be to clean, if covered in that sticky red mud that can be prevalent after rain in the outback?
There are a couple of photos of our canopy in My Profile page, on the day we took delivery. Happy to answer any questions you might have. :-)
593051
Follow Up By: The Landy - Monday, Nov 23, 2015 at 22:23
Hey Bob,
Not sure it would be a good outcome financially, Dave Vella got a slice of my wallet. But my choice was around quality, not price, and after two units I have no hesitation recommending him.
But you are right, horses for courses, and understanding your own requirements is key to getting value for what you want.
Research is king. And you can almost guarantee that putting a canopy on the back made of alloy or alternatives, will almost certainly mean upgrading
suspension and GVM.
Cheers, Baz
861235
Reply By: AlbyNSW - Monday, Nov 23, 2015 at 21:39
Customfit Fabrications at Windsor will be able to do it for you too. Happy with
mine that they made
593057
Reply By: blue one - Tuesday, Nov 24, 2015 at 08:31
Thanks everyone. That should be enough to get me into trouble.
Steve
593066
