Thursday, Nov 26, 2015 at 08:38
So I guess to put it in simple terms, if we talk about grams/kw.h.
Regardless of your engine capacity, it is mainly about the number of kilowatts you use - tow a big van at higher speeds you use more kw and so more fuel.
If you have an older diesel it will be less efficient than modern ones.
Just mainly see a lot of common sense there.
I drive an old 80 series aftermarket turbo towing a 1700kg Vista Crossover.
My mileage varies from 19 l/100km at 100kph down to 16.3 towing at 90 kph.
I know I could get better if I updated, but the overall saving would only be about 20% on fuel (maybe $200 per year ). Devaluation on a newer car would be triple that.
The economics favour sticking with the older car. However if you want more features, comfort and safety, update.
Comes down to wants vs needs.
861332
