Goldfinder....are you out there???
Submitted: Monday, May 24, 2004 at 16:57
Member - Roachie (SA)
G'day all,
I was wondering whether our mate "goldfinder" was still active on the
forum? Back on 27 January, we were discussing radiators etc and he advised he had just purchased and installed a PWR alloy radiator into his GU 4.2T/D.
If you're there mate; could you let me know how your rig has been behaving lately as far as temperature goes please.
Reply By: Des Lexic - Monday, May 24, 2004 at 17:05
Message for Pesty, Would the Parole's overheating issues be caused from all the hot air coming from the drivers
seat.LOL
59928
Follow Up By: Member - Roachie (SA) - Monday, May 24, 2004 at 17:22
Des,
Not true....
All the hot air from the driver's
seat gets expelled through the operator's exhaust system!!!!
321532
Follow Up By: Member - Pesty (SA) - Monday, May 24, 2004 at 18:36
Des The poor patrols o/heating problem is caused by several factors,
1 It is not powerful enough to haul 3 ton of 4by let alone 1.73 ton of acc.
2 It uses twice the fuel of a tojo so creates excessive heat build up under the bonnet by burning too much fuel
3 The driver is full of hot air and instead of cool air coming out the vents hot air is forced down the vents o/ heating engine bay
4 Its to high off the ground so is closer to the sun
He showed me a couple of extra tow hooks he is going to fit on the w/end so that when it o/heats he can be easily towed for a few hundred ks at a time buy the nearest tojo. LOL
321554
Follow Up By: Des Lexic - Monday, May 24, 2004 at 21:03
Pesty, had to larf when I read Roachies reply about expelling his hot air out of his exhaust system. Be a bit hard when your full ofbleepe and when he blows that out, that would be the best part gone.LOLLOLLOL
321578
Follow Up By: Member - Bernie. (Vic) - Tuesday, May 25, 2004 at 01:15
Al That got me RAOTFLMAO
Cheers & enjoy the W/E on the Murray .
321610
