Tuesday, Dec 29, 2015 at 20:27
Make sure you understand the weights on your compliance plates...both for your tug and Van ATM GCM.Tare. Ball weight etc. Keep it legal and avoid insurance and warranty problems.
In no particular order this is my checklist so far...for a mix of bush and
caravan park sojourns.
Grey water tank?....will probably self fit.
Under van...
Check welds and plumbing.
Is Chassis galv or painted?
Chassis size 100mm or 150mm?
Does drawbar A frame extend back to axles?
Towball height vs Tug towbar
Offroad hitch DO35 or similar.
Anderson terminals on van?
Caravan external cladding and colour options?
Extra supports on rear bumper for added wheel/jerrycans etc
Reverse Camera?
Reposition washing machine to create space for Generator hatch. (Only applicable for some makes of vans)
Awning, extra support bracket in middle
Extra solar panel and battery. (300w of solar minimum and 2x 100ah batteries minimum)
4" lift on chassis with larger rims and genuine offroad tyres. (Some makes only)
Exterior gas bayonet.TV plug and power points.
Check exterior lighting.
Size of TV supplied.
Cupboards convertible to drawers, particularly under the seating.
Mattress upgrade or have own made?
Storage for deckchairs and table.
Self tuning
Satellite TV fitted at Manufacture. (Mounts need to be built into roof)
Brand of electrical controller and its abilities and limits. Will it accept extra solar panels etc.
12v fan built into
caravan for night use in bedroom.
Stability control (ESC..make and model)
Where does aircon condensate water drain to?
Off side shade sail rail fitted.
Check standard of silicone application around vents and up on roof.Look for tidy workmanship.
Proper window over bed? (If at front of van water sealing may be an issue)
Finish inside cupboards? Is beading around cupboard openings or is it just wood cut?
Soft start fitted to Aircon. If Ibis 2 get upgrade to Ibis 3.
City/
Camp water supply pressure controller
Do water tanks fill without air locking?
Is a wiring diagram available
ATM. Get manufacturer to upgrade and stamp Compliance plate accordingly. 550kg/600kg needed. Should be no or minimal cost.But expensive to do retrospectively.
Make of appliances such as microwave, range hood. They vary considerably.
Control panel for electrics and water? Cupboard mounted or on van wall etc?
Is TV bracket quick release?
Type of step fitted and ease of use.
These are items we
check...its not exhaustive ....plus we try and assess resale and eye appeal (the wow factor)
I'm not electrically minded or an engineer...no doubt others can add much more to this list.
594281
Follow Up By: Member - John - Tuesday, Dec 29, 2015 at 21:19
Witi, I "thanked" you but then thought that your comprehensive reply needed a more personal reply. Thanks, it has concisely listed things to consider, most I would never have though of until after a purchase. Thanks, a big thanks.
862644
Follow Up By: Members - Bow & Nan - Wednesday, Dec 30, 2015 at 08:30
Grey water tank is a waste of room and weight.
862665
Follow Up By: Member - John - Wednesday, Dec 30, 2015 at 10:16
Bow and Nan, "
Grey water tank is a waste of room and weight.", that it maybe, but more and more a requirement in a lot of
places.............
862668
Follow Up By: Members - Bow & Nan - Wednesday, Dec 30, 2015 at 14:37
The only place I know you need a
grey water tank is
Cooktown.
We never
camp near towns.
862684
Follow Up By: Member - John - Wednesday, Dec 30, 2015 at 15:39
Bow and Nan, I do understand what you are saying, but as more and more
places, even
free camp areas etc require
grey water tanks it is something that has to be considered. Threads 130156 and 98211 have some useful information....... Enjoy your travels.
862688
