Reversing Lights
Submitted: Tuesday, May 25, 2004 at 01:19
ThreadID: 13133 Views:1702 Replies:6 FollowUps:1
Were do you get reversing lights in black with the handel on top? most commonly seen on rear weel carriers. seen plenty but never found them in a shop in WA. I need them 4wd & camper so I can see in the dark. Ps have serched this sight.
Reply By: John - Tuesday, May 25, 2004 at 02:08
Have a look at kaymar.com.au for there rear light set up.
AnswerID: 60010
Follow Up By: Willem - Tuesday, May 25, 2004 at 09:10
Or Eric's shed :-)
FollowupID: 321625
Reply By: KENM - Tuesday, May 25, 2004 at 09:04
Try Hella they make one.
AnswerID: 60026
Reply By: Shaker - Tuesday, May 25, 2004 at 09:29
They are commonly called a worklight, often used on tractors.
AnswerID: 60029
Reply By: Truckster (Vic) - Tuesday, May 25, 2004 at 09:41
Yup Hella is the place.. Supercheap auto, or any auto place can get them in for you.
AnswerID: 60031
Reply By: Member - Steve G (WA) - Tuesday, May 25, 2004 at 09:48
The one you are thinking of is the hella matador halogen work lamp part number 1511 12v 55w,they are a bit big for the application you intend to use them for. you could try using the 1533 halogen ff work lamps they are half the size but dont come with a handle on them.the size difference is the 1511 is 227h x 168w compared to the 1533 127h x 112w .hope this helps ROX
AnswerID: 60033
Reply By: Member - Don (QLD) - Tuesday, May 25, 2004 at 20:15
G'day
There is a place called Mechtric they are just about it every state they do lights and sirens for Automotive commercial and industrial applications.
Good Luck
Don
AnswerID: 60133
