solar battery charging
Submitted: Tuesday, Feb 09, 2016 at 15:30
Hairy (NT)
Gday,
Here is my current set up......
aux battery with a wire leading to outlet 1 (in side twin cab)and then another wire from outlet 1 leading to outlet 2 (on the back of ute), so I can use my fridge in the back of the car or on the back of the ute.
Question. ?........is it ok to plug my solar panel into outlet 2 to charge battery while fridge is plugged into outlet 1 and running?
Reply By: Member - mechpete - Tuesday, Feb 09, 2016 at 16:07
hi
I run my fridge of the battery at the same time the solar panel is plugged in to for charging
haven,t had a problem
cheers mechpete
596044
Follow Up By: Hairy (NT) - Tuesday, Feb 09, 2016 at 16:38
Yeah, ive always done the same.......but this set up, the power from the solar could be gong direct to the fridge not the battery?
Im not sure if it makes any difference?
864855
Reply By: Member - mechpete - Tuesday, Feb 09, 2016 at 17:02
if the solar panel is connected to a battery , the power will go to the battery
an the fridge will draw off the battery
596046
Follow Up By: Hairy (NT) - Tuesday, Feb 09, 2016 at 17:23
I should have added, there is a fuse between the aux battery and outlet 1..........I wonder if puttingI a fuse in the fridge lead would over come any issues.
864859
Reply By: HKB Electronics - Tuesday, Feb 09, 2016 at 18:38
Yes what you suggest is ok but it would be more efficient if the solar regulator was plugged in as close as possible to the battery. If your not worried about getting every amp you can into the battery then what your thinking should work ok, providing the existing wiring can handle the output of the solar panel.
596054
Follow Up By: Hairy (NT) - Tuesday, Feb 09, 2016 at 18:45
Sould I put a fuse in the fridge lead, or cant the solar panels do any damage?
864866
Follow Up By: Hairy (NT) - Tuesday, Feb 09, 2016 at 19:54
Also.......I have a Piranha system on the dual batteries.
If the solar panel was plugged into the main battery, Im assuming it wouldnt charge the aux battery even when the main battery is fully charged as it would need the ignition turned on to open the solanoid ???? Could it be as simple as plugging it on the main battery and turning the ignition on? OR........ just put another unfused outlet on the aux battery to plug the panel into?
CHEERS
864873
Follow Up By: Stephen F2 - Tuesday, Feb 09, 2016 at 21:45
Hi HKB so the solar regulator is best close to battery.I have 2 cig plugs in back of tub.So if I plug in solar panel into one of them it will it charge my aux battery.I bought the Hilux with already set up with Redarc system but owner did not explain its workings.I think have to get someone to do some testing on it and go to ARB ask them to tell me what Redarc system I actually have.Also will 100watt deep cycle as aux be enough to run the Engel 39l fridge cheers
864884
Follow Up By: Member Andys Adventures - Wednesday, Feb 10, 2016 at 13:09
Hi Stephen,,
I would not use the cig plugs for
solar power..... Get a Anderson plug for that.......Your 100W panel will run your Engel fridge as a freezer or fridge with power left over for lights or tv.etc..
Cheers Andy
864931
