<span class="highlight">Caravan</span> Water problem
Submitted: Wednesday, Apr 13, 2016 at 09:44
Maisie K
Hi! All, We have a 2013,22ft Jayco Sterling full van, water OK from tanks with pump going, but when the high pressure hose is connected we get a very slow trickle, I then need to switch on pump, but by doing so the pump aspirates the water from our tank and not the high hose, will welcome any suggestions. Bob K
Reply By: pmk03 - Wednesday, Apr 13, 2016 at 09:55
There is a pressure reducing valve in the mains line, probably under the van near the connection point. It is a brass fitting. Sometimes these have been known to be faulty.
Jayco have been good with this issue. Give them a call
Cheers Paul
598588
Follow Up By: Notso - Wednesday, Apr 13, 2016 at 10:05
I'll second that. I had to dismantle
mine a while back, there was some rubbish blocking the valve . Some of these pressure reduction valves are sealed and some you can service. Don't be tempted to remove it altogether as some of the appliances in your van will not take the high pressures found in some towns.
867766
Reply By: Maisie K - Wednesday, Apr 13, 2016 at 14:08
Thanks Chaps for the info, will give it a look see! Bob.K
598596
Reply By: johno59 - Tuesday, Apr 19, 2016 at 18:37
We have had the same problem. I thought it may have been low mains oressure so tommorow I will look for that valve. Thanks all for your help
john
598864
Reply By: Stone Stomper - Friday, Apr 22, 2016 at 08:56
The water pressure limiting valve can be pulled apart and then you need to remove the spring and give it a good stretch by hand, replace the spring and you will have perfect water pressure still allowing the limiter to do it's job limiting high water pressure.
You may need to do this every 12months or just when the pressure is dropping again.
Bob's picture is what it looks like and you can just push the
John Guest fittings in to completely remove to stretch the spring.
Much cheaper than replacing.
Christian
598978
Follow Up By: Maisie K - Friday, Apr 22, 2016 at 10:06
Thanks Chaps, I have discovered the stop valve has broken down, heading towards Dubbo in a few days after our stay at The
Boggabri Drovers Campfire to try and purchase one, but will give your suggestion a try before I buy one Thanks everyone for your info.B.Kelly
868194
