Pajero
Submitted: Thursday, May 27, 2004 at 15:51
ThreadID: 13215 Views:3037 Replies:4 FollowUps:2
Hi all we have just bought Pajero and wondering how to get back seat to fold up againts back of front seats, its a NJ GLX 96 Wagon.Do they fold right ?is there a trick to it ?
Thanks all.
Reply By: flappan - Thursday, May 27, 2004 at 16:27
Mines an older Pajero , but anyway.
The back of the seat needs to be flat first (can usually be done from either side).
Then , at the bottom of the seat , in the middle , at the back , is a Metal Rod , that looks like a handle. Pull upwards on that .
As I said though , its an older PJ , so whether its the same or not . . . .??
Don't know.
Don't you have a manual ?
PS . . . I recall the instructions for mine are actually sewed onto the seat ?
AnswerID: 60458
Follow Up By: Quino - Thursday, May 27, 2004 at 16:32
Thanks flappan for your quick reply, didnt come with owners manual we have a look.
FollowupID: 322042
Follow Up By: flappan - Thursday, May 27, 2004 at 17:00
A bit more.
Bearing in mind , mine is an older PJ.
On the sides , you have the normal lever. On the pj's this tilts the Seat , and allows the whole seat to slide foward and back . . . thats not what you want.
On my PJ , there is a D shaped handle on a string (on either side) , pull on this , and the back of the seat folds down.
You then pull on the rear bar. (I think there is also a lever in the middle of the seats , near the seat belts).
Should at least give you an idea on what to look for.
FollowupID: 322048
Reply By: cluffy - Friday, May 28, 2004 at 10:15
Quino
just got a 93 nh and i have instruction book and still can't get it to fold up pulled levers pushed and shoved still won't move forward passenger side goes to slide drivers side will not move
cluffy
AnswerID: 60572
Reply By: dougie - Friday, May 28, 2004 at 14:18
I get my wife to do it,
They are apian in the arse set up and It frustrates me no end mine, is 99 model. They make a motor that will go 500,00ks and cant make a simple seat system.
Other than that the best car I have had.
never let me down,(only once Got real dodgy fuel at eucla at xmas cost me a fortune and a graet deal of stress) but not the cars fault.
AnswerID: 60619
Reply By: Fimez - Friday, May 28, 2004 at 14:44
I have a '96 NJ Pajero. You will see one of those 'pull-up' buttons on the shoulder of both of the back seats. Pull them up, and the seat back folds down onto the seat seat. (where yer bum goes!) From here it's just a simple case of lifting the now folded seat from the back near the floor. They will lock in place once up against the front seats, and you have to pull a release lever to set them back down again. Took me AGES to figure it out when I got mine.
The lever at the side of the seats just slides the seating position. Hope this helps!
AnswerID: 60624
