Saturday, Apr 30, 2016 at 09:36
Rojac - Shane has hit the nail on the head - stick with the good brand names if you want want quality tubes.
The better quality tubes generally come from Korea. Hankook tubes should also be satisfactory quality.
A good quality 7.00/7.50 x 16 tube will fit a wide range of tyre sizes, but all sizes won't necessarily be stamped on the tube.
On page 86 of the catalogue below, you'll find all the sizes that a "premium" 7.00/7.50 x 16 tube will fit.
Carlisle Tire Catalog
Mick Hutton from Beadell Tours has a good page on his experiences with running tubed 4WD tyres on bush tracks.
Beadell Tours - tyre report 2013
Mick mentions a couple of things that are of importance when using tubes.
One (which I knew about, and have always done, myself), is to use plenty of talc or "French chalk" when fitting tubes.
The talc provides lubrication between tyre and tube that reduces friction and prevents heat buildup and chafing. It will also save the tube if you get a sudden flat at speed. No talc means the tube becomes rubber salad by the time you've stopped.
The other point Mick mentions is sealing split rims with silicone to prevent the ingress of water and grit. This is not something I've heard of before, but it makes sense and it obviously works for him.
Mick is pretty scathing of most tyre shops performance. Note his annoyance at tyre shops leaving stickers on tubes that led to tube failure.
One thing I have found, is that tubes are becoming more expensive and harder to find every year. The tyre industry doesn't want to know about tubes.
I have a 5 ton truck fitted with tubed 8.25 x 16's and even these tubed truck tyres are becoming very expensive, and harder and harder to find. The industry only wants tubeless, they regard tubed tyres as ancient technology.
Another point is, that there is available, an externally-threaded valve stem fitted with a nut that is clamped to the rim, that helps prevents rims from spinning inside the tyre and ripping the valve stem off, when operating with heavy loads and low tyre pressures.
These valve stems are called a rally-type valve stem, but I don't know this stems part/code number.
Cheers, Ron.
868571
