<span class="highlight">BATTERY</span> Monitor App
Submitted: Sunday, May 15, 2016 at 18:07
GREENDOG
Any one got this set up to Monitor your Duel
Battery system
Battery Monitor
Reply By: Jackolux - Monday, May 16, 2016 at 00:33
I have one seems to work ok
600129
Reply By: Malcom M - Monday, May 16, 2016 at 07:36
Another one on Amazon for US$24
http://www.amazon.com/dp/B00X1MMNIG/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=1944687742&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0184XHL1K&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1H5TBV17F44VVRSXHWC6
600130
Reply By: Member - Boobook - Monday, May 16, 2016 at 07:37
I don't have one. I looked at it and thought what a great idea. After looking at the detail more, I came to the conclusion that while it looks sexy, it is probably another toy that I wouldn't really use.
The concept of measuring the camper
battery remotely is really appealing but using a phone app to measure it over bluetooth isn't perfect.
The reviews on google play pretty much all say it is flaky and unreliable. And the specs say the range is up to 6m in open air.
play store site inc reviews
"** Subject to environmental conditions , obstructions such as bonnets , car panels , solid objects will reduce the transmitters range." And that is reduced from 6m.
After considering it more, I think you need a dedicated 'always on display', not something the you
check from time to time when you remember by opening an app.
Unfortunately Bluetooth isn't really the right radio technology to go through several sheets of steel panels, and about 8 - 10m distance. Think of how dodgy and choppy it is with music when you are playing it even less than 5m from a stereo in free air!
I'm still looking for something to do that job at a reasonable price
600131
Follow Up By: Jackolux - Monday, May 16, 2016 at 08:45
I use mine for the AGM batt fitted under the right side of my alloy tray on my Dmax
with the phone in is holder on the dash it connects no problem .
Sitting in
camp I can just pick up my phone and
check how my
battery is without even getting up out of my chair , haven't really taken much notice of distance but I guess 5 or 6 metres is about right .
Compared to the SC2 in the vehicle and multimeter , it's near enough
869443
Follow Up By: Member - Boobook - Monday, May 16, 2016 at 10:08
Does it set off an alarm in your phone if the
battery drops below a certain amount, say 12.2V?
869445
Follow Up By: Jackolux - Monday, May 16, 2016 at 17:44
There is no alarm
869462
Follow Up By: Member - Trouper (NSW) - Monday, May 16, 2016 at 19:40
You can buy a 12v Panel Meter for about $10 on Ebay. Very simple to connect to your
battery, 2 wires one Neg one Pos . Then you have a permanent display
869465
Follow Up By: Member - Boobook - Monday, May 16, 2016 at 20:14
A wireless one?
869472
Reply By: Allan B (Member, SunCoast) - Monday, May 16, 2016 at 22:31
There are a number of models available. At a range of prices.
Some have alarms, some measure current as
well as volts. Even temperature.
I would not want one. I go bush to get away from the b.. phone!
600171
