Monday, May 23, 2016 at 20:20
So According to manuals at
http://arkcorp.com.au//Content/manuals/ArkPak%20AP730%20manual%20120315.pdf
Solar panels should be connected to main big terminals (Done)
Pack switched on at isolator.
The front meter is then disabled from reading current from
solar panels coming in.
A
test would be open box and connect
solar direct to battery.
Also when charging batteries the closer they are to fully charged the less current they will absorb.
Best advice is to get multimeter If it has a current setting at least 10 a and put in series on positive charge lead of
solar panel this will definitely tell how much charge is going in.
Another is to using a multimeter on Volt setting after a day of charging leave over night with nothing connected the Voltage should read 12.8 v This is generally what fully charged batteries settle to.
869858
