Yet another question
Submitted: Monday, May 30, 2016 at 12:28
lou_r
Hi all, just putting together an itinerary and cant figure out which way would be better to go from
Sydney to
Birdsville. We would love to see the
Cordillo Downs Shearing Shed etc but we will be leaving
Molong on Friday the 1st (very early) and want to be in/around/near
Birdsville Sunday night the 3rd. I'm thinking that is nowhere near enough time. Any suggestions on alternate routes? I have googled but no I'm just confusing myself completely :)
Lou
Reply By: lou_r - Monday, May 30, 2016 at 12:30
Interesting alternate routes that is :)
600730
Reply By: Member - mark D18 - Monday, May 30, 2016 at 12:50
Lou
That's a fair way out of your way in a short time if you are going to
Birdsville
You may need another 2 days or so , even that would be pushing it . I gather you are going though
Innamincka . I think you may need to give the readers a bit more info.
600732
Follow Up By: lou_r - Monday, May 30, 2016 at 13:00
Thanks Mark, I'm just trying to figure out if going through
Innamincka is an option or if we should wait and do that on the way back with more time. Also if we dont have enough time to go up via
Innamincka I'm looking for the best alternate option.
870073
Reply By: vk1dx - Monday, May 30, 2016 at 14:20
Considering what you said to Mark just above here;
Go direct to
Birdsville via Drive from Obley Rd, A32,
Mitchell Hwy, Adventure Way/Bulloo Developmental Rd, and
Birdsville Developmental Rd to
Birdsville
22 h 17 min (1,734 km).
If you have time coming
home then do a side trip to
Innamincka via
Cordillo Downs and then back up to the black top and
home the way yopu came.
This would be the fastest way and I simply got it from Google Maps.
If you have more time for the trip
home, then consider
Innamincka to
Tibooburra,
White Cliffs,
Wilcannia,
Nyngan and back to
Molong. Thats 56 h (3,267 km)
Not a small trip but if you think of it - It is a bloody long way back to see what you missed.
All this straight from Google Maps.
600736
Follow Up By: lou_r - Monday, May 30, 2016 at 14:37
Thanks Phil much appreciated :)
870076
Reply By: Nomadic Navara - Monday, May 30, 2016 at 16:07
The best way to pn quick trips is to use Google Maps or some other travel planner.
Molong to Birdsville
That reckons you have 1734 Km to drive (or 22 h 17 m.)
600739
Follow Up By: lou_r - Monday, May 30, 2016 at 17:05
Thank you that's the way I found was hoping for a few side tracks but that looks good :)
870081
Reply By: Baz - The Landy - Monday, May 30, 2016 at 18:44
You could look at the following.
Molong >
Wilcannia >
Tibooburra >
Innamincka >
Cordillo Downs >
Birdsville, or
Molong >
Cobar >
Louth > Wannaring >
Tibooburra >
Innamincka >
Cordillo Downs >
Birdsville
There are options, but either way you go you’ve got a fair bit of distance to cover in 3 days.
Cheers, Baz – The Landy
600746
Follow Up By: Nomadic Navara - Monday, May 30, 2016 at 19:04
The first route is only a few kilometres longer but it stretches the driving time out fro 22 1/2 hours to 40.
870083
Follow Up By: Baz - The Landy - Monday, May 30, 2016 at 19:49
Probably, but I think the OP is looking for alternatives, here they are...
Cheers...Baz
870092
Follow Up By: Nomadic Navara - Monday, May 30, 2016 at 20:32
You gave an alternative. The OP has a time constraint. You did not give him any guidance as to the implications of going that route so I did it for you.
870094
Follow Up By: lou_r - Monday, May 30, 2016 at 21:12
Thanks for the info guys much appreciated :)
870100
Reply By: micknchrisw - Tuesday, May 31, 2016 at 12:28
Lou, a big day and you could reach
Eulo via Cunamulla from where youll be. head up to Dubbo and north to
Bourke.
From
Eulo its an easy run across to Innaminka, then over
walkers crossing and up to
Birdsville on the track.
I took this route with a camper trailer, loaded for a 7 week fishing/hunting trip in the NT.
My Itinerary;
Day 1, from the Central Coast to
Eulo.
Day 2,
Eulo to
Innamincka, easy 500k drive.
Day 3,
Innamincka to
Birdsville, did this with a motor that went into limp mode a 150 times due to an air leak in the fuel filter.
Regards Mick.
600775
Follow Up By: lou_r - Tuesday, May 31, 2016 at 17:43
Thanks Mick that sounds good,
How long did the last leg take even with the fuel filter issues ?
870142
Reply By: micknchrisw - Saturday, Jun 04, 2016 at 09:47
Yeh Lou, even with the car mucking up, we did the 300 odd K's in 6hrs. Not a bad track across Walkers.
600939
