<span class="highlight">Solar</span> regulator
Submitted: Friday, Jun 03, 2016 at 17:32
LAZYLUX16
Hi I am after a regulator for my 100watt
solar panel to charge my Exide 95ah Battery seems many Chinese rubbish and good ones out there thanks.
Reply By: Peter - Friday, Jun 03, 2016 at 19:01
I use a Blue
Solar regulator MPPT 75/15 by Victron Energy. It works a treat. The only trick is that you need to connect to battery first before
solar. This seems to be true for most good MPPT controllers.
This is a true MPPT and is very efficent
600911
Reply By: Rangiephil - Friday, Jun 03, 2016 at 20:48
I have a GSL Australian designed and produced MPPT.
I have had it now for several years and it has performed
well with my 120Watt panel.
http://www.gsl.com.au/mppt12.html
Regard s Philip A
600920
Follow Up By: Frank P (NSW) - Friday, Jun 03, 2016 at 21:01
I, too, have had excellent results from a larger GSL controller with panels in a series-parallel arrangement, total 440 watts. Big advantage for me is that because it is fan-cooled it can be mounted any way except face down. Most others are convection cooled, requiring upright mounting on a vertical surface and good natural ventilation. Not always possible in a caravan or camper.
It's good to be able to support an Aussie product.
Link
870288
Reply By: Member - William B (The Shire) - Friday, Jun 03, 2016 at 21:01
I recently brought one of these through ebay.
MPPT controller
So far I am very happy with it.
I decided on this one because of some positive reviews on YouTube.
William
600922
