Prevention of dust and dirt coming in under Waco Compressor fridge
Submitted: Thursday, Jul 21, 2016 at 17:05
Member - Martin K
Can you purchase marine ply covers to cover exterior vents when travelling ? and fitting extra 12 volt fan for circulation
Any thoughts or ideas ???
Reply By: Peter_n_Margaret - Thursday, Jul 21, 2016 at 17:38
A compressor fridge does not have to be vented outside.
But the compressor and condenser still need good air circulation for optimum performance and an extra fan can help that. I run one via a 50C thermal switch on the compressor, so it only runs when things get too hot.
602620
Follow Up By: Member - Martin K - Thursday, Jul 21, 2016 at 17:48
Thanks Peter
Would I have to fit an extra 12 volt fan , one to draw in air and one to push the air out internally if I cover the outside 2 fridge vents?
872268
Follow Up By: Peter_n_Margaret - Thursday, Jul 21, 2016 at 17:56
That's a tough question without having any idea what it looks like Martin. Suffice to say the heat must be removed one way or another.
872270
Follow Up By: Les - PK Ranger - Tuesday, Jul 26, 2016 at 10:30
. . . and cool air has to get in.
Is this fridge located outside the vehicle on an open tray ?
When you say in the topic title "dust and dirt coming in under Waco Compressor fridge" what exactly does this mean, from under the tray or floor ?
Normally there is an inlet grated section (or two) and an outlet for air pumped through.
If there's dust getting inside a vehicle causing an issue, then far better to work on keeping that out and the fridge will be fine with an occasional blow through with moderate compressed air.
872424
Reply By: Motherhen - Sunday, Jul 24, 2016 at 22:39
Our caravan fridge has vents to the exterior. With the angle of the vents, very little dust comes in, and what does settles on the 'floor' around the compressor and can be vacuumed out when we get
home. It is sealed from the interior of the van.
602769
