Monday, Aug 01, 2016 at 16:58
I do sheet metal for a living, so have twist drills, step drill and hole saws.
Twist drills are fine for thin sheet, provided the drill is on the small side. Bigger drills have a habit of grabbing and twisting the thin sheet up the flutes and distorting the material.
Step drills are best for cutting a hole in thin sheet and still maintaining the center you were aiming for. They cut and de-burr without distorting the material. You have to keep the RPM down as they do have a nasty habit of getting hot and burning the cutting surface, particularly in steel. A squirt of WD40 as cutting fluid helps them last a lot longer.
Holesaws are OK for aluminium, but good ones for steel are dear as poision. They can grab and damage the surface when you are starting, so you need to take car there, they also leave a nasty burr that needs to be cleaned up. If whatever you are fitting has a bezzle, then you can often hide any damage a few mm from the hole edge.
As for the switch, I just used plain automotive switches on my motorbike. After 6 years of mud and dust they still worked fine.
872670
