Alloy Rim - bush tyre repairs
Submitted: Monday, May 31, 2004 at 12:47
ThreadID: 13326 Views:3165 Replies:1 FollowUps:2
Hi all, what is the best way to minimise damage to an alloy rim when changing a tyre with tyre levers? are there any simple/inexpensive methods?I can break the bead with no damage using a jack but from then I find it very difficult not to damage the rim, I have seen these plastic pieces that clip on the rim but they are also a bit tedious to use. Any other ideas?
Any advice/opinion would be appreciated. regards Mark
Reply By: Gordon - Monday, May 31, 2004 at 13:03
Hi Mark,
Given that you will only be able to break the bead with a jack provided there is still sidewall left, you will undoubtedly find yourself in the position that you need a dedicated bead breaker.
You will find that Tyre Jaws not only break the bead but also facilitate tyre fitment without damage to the rim.
Do yourself a favour and check them out.
Gordon
AnswerID: 61000
Follow Up By: Bonz (Vic) - Tuesday, Jun 01, 2004 at 10:10
the B&B Beadbreaker does the same, gets the tyre off without damaging the rim. check them out also
FollowupID: 322717
mmmmmaybe its R&R beadbreaker
FollowupID: 322718
