Portable Solar Panel
Submitted: Tuesday, Aug 23, 2016 at 14:31
ThreadID: 133281 Views:6358 Replies:9 FollowUps:8
Hi Guys,
Any advice on selecting a portable solar panel? I have a dual battery setup through a Redarc BCDC1240 and the MPPT solar relay with a 165ah 12v deep cycle agm battery. Needs to charge the battery and run a 80L engel fridge on camping trips etc. I am looking at a 130w-160w solar setup.
These guys are around the corner from me and their batteries are good. Anyone had one of these or know anyone who has?
http://www.aussiebatteries.com.au/solar/portable-panels/130wm-12v-portable-solar-panel-with-kyocera-japanese-cells
http://www.aussiebatteries.com.au/solar/portable-panels/160wm-12v-portable-solar-panel-with-kyocera-japanes
Reply By: Sand Man (SA) - Tuesday, Aug 23, 2016 at 15:25
Hi Ricky,
The panels you have referenced look to be good quality and reasonably priced and buying from the guys around the corner would give you additional piece of mind.
Either one would be suitable, the 130w just taking a little longer.
Just one thing to keep in mind.
Most portable panels include an on board regulator and if you are connecting the panel to your Recarc, the on board regulator will need to be bypassed, so that only one controller is in the circuit.
I have a 120 watt panel array and have added a second cable circuit (bypassing the panel's regulator) to connect to my Ctek dc-dc charger's solar input port. The Ctek has a MPPT solar regulator built-in and is more efficient than those normally mounted to the panels.
With this arrangement an uncontrolled circuit can be connected to an "external" controller, or the original controlled circuit can be used to connect direct to a battery bank should you desire.
Bill
AnswerID: 603742
Follow Up By: AeolusRicky - Tuesday, Aug 23, 2016 at 15:30
Thanks Bill,
The system come with a bypass setup and an onboard regulator just in case I want to use it away from the car on another battery. I am pretty keen to get it running and crack a cold one :)
FollowupID: 873350
Reply By: Member - rooster350 - Tuesday, Aug 23, 2016 at 15:49
Probably quite good and using the guy around the corner is also a good idea, but for $239 panel on fleabay...I would be thinking very hard about my pocket...cheers
AnswerID: 603745
Reply By: 2517. - Tuesday, Aug 23, 2016 at 15:51
Hi I would buy the biggest panel you can handle maybe a 200 w that is a big battery and a big fridge to run in hot weather.
AnswerID: 603746
Reply By: warren h1 - Tuesday, Aug 23, 2016 at 17:20
Hi Ricky
I have just purchased this one
https://www.vicoffroad.com.au/sport-outdoor/solar-panel/pair-led-tail-lights-stop-indicator-lamp-e205-truck-trailer-boat-12v-waterproof.ht
And it seems to work good
Warren
AnswerID: 603748
Reply By: carl h2 - Tuesday, Aug 23, 2016 at 17:28
hi rick I have the130 watt sharp panel you are looking at with the redarc bcdc 1240 and waeco 80 ltr fridge and 2 x 105 AH batteries . you must bypass the MPPT controller for the BCDC charger to work this 130 watt panel has no problem keeping the charge up to the 2x batteries cheers.
AnswerID: 603749
Reply By: chaz r - Tuesday, Aug 23, 2016 at 18:22
That depends how portable you really need. I've got this solar panel.
http://www.ebay.com.au/itm/200W-Folding-Solar-Panel-Kit-Caravan-Camping-Power-12V-Mono-Charging-Battery-/251801381192?hash=item3aa0882948:g:D~UAAOSwHoFXs8xh
There is even a bigger sized folding solar panel. But the question is, how much power is required.
My solar panel puts out 10A, running my waeco 60L fridge/freezer and an inverter to keep up TV and some LED lights on going. Used a couple of times a day, but keep fridge running all the time. Entire power consumption is nearly 7A, but constant current drawing is approxi 4.5A.
Guess you could get even a small portable one, and AGM batteries are always highly recommended!
AnswerID: 603753
Reply By: swampy - Tuesday, Aug 23, 2016 at 19:18
hi
Ricky,
I have purchased 2 sets of panels from these guys b4.
Both 195watt 1x sharp 1x Kyocera both trifolds
Good warranty 1st set arrived damaged they replaced them promptly.
You can customize order
whatever wire size say 8b&s x 6mtrs long
plug ends, andersons etc
wire it with a bypass [so u can use with or without controller on panel ]
possible to order without controller
There alloy cases are rubbish select the carry bag
If its available get a three piece [tri fold = little easier to carry ]
check all there crimp terminals ,u will find some loose ,I did
consider storage eg overall size
Most modelling suggest 200watts per 100ahr battery
eg sun harvest =say 5.5 hrs effective sun shine min winter 4 max summer 6
[per 200 watt] 11amps x 5.5 hrs = 60.5 amp
solar system is more like 80% efficient = 48.4 amp harvest
50% is the recommended capacity use of agm
100ah batt = 50ah usable
Refer to camper trailer Australia site
Fridge/freezer can double consumption in hot weather over 25 deg cel compared to 35 deg cel
At a guess an 80lt could consume 40ah to 80ah in a 24hr period
Solar at least 160 watt set up
swamp
AnswerID: 603754
Follow Up By: Ben01 - Tuesday, Aug 23, 2016 at 22:54
Hi mate any idea how you customise on the website or do you have to call them??
FollowupID: 873363
Follow Up By: swampy - Wednesday, Aug 24, 2016 at 00:43
hi
you need to call to customize
FollowupID: 873366
Reply By: Ben01 - Tuesday, Aug 23, 2016 at 22:59
I am also interested in that 130w panel from Aussie batteries and solar - especially seeing as it's currently on special it seems like a very good price.
Would love to know what they mean by "heavy duty" cable though.
AnswerID: 603763
Follow Up By: carl h2 - Wednesday, Aug 24, 2016 at 16:58
its 6 meters of 6mm dual core cable.
FollowupID: 873375
Reply By: Dean K3 - Wednesday, Aug 24, 2016 at 19:22
you will be limited to maximum of 250w (300w peak) input for solar per redarcs instructions.
i can't say anymore than what has already been mentioned however from a space perspective maybe look at folding polycystaline panels. large fold out units are painful to carry at times (humble opinion why i only have a 80w unit)
Bloke over in WA has both 80 w and 120w which when folded up (concertina like a map) compact is about 100mm thick at best and compared to another company doign similar thing priced competitive
not sure if sending links is permitted
http://www.rei.net.au/solar-battery-charging/
AnswerID: 603788
Follow Up By: Ben01 - Wednesday, Aug 24, 2016 at 21:02
That website is a joke. No information on pricing whatsoever and there isn't even any info on where to buy the products.
Sorry but if you can't give me any information about the product (except for the usual 'ours are the best' dribble then it's a waste of my time as far as I'm concerned.
FollowupID: 873385
Follow Up By: Bob Y. - Qld - Thursday, Aug 25, 2016 at 13:56
Seems like a pretty arrogant reply, Ben, to someone who is just trying to help you.
Maybe you ought to do your own research, then you'd only have one person to blame if it wasn't satisfactory.
FollowupID: 873415
Follow Up By: Ben01 - Thursday, Aug 25, 2016 at 14:56
Sorry Bob I have just re read my reply and realise it's probably being interpreted wrong.
I wasn't referring to the poster mate - I was referring to the website. If they can't provide info on their website about their product then they are wasting my time. With so much competition out there its hard to believe companies still have vague product descriptions etc because they want you to inquire so they can hook you in. It's frustrating.
FollowupID: 873417
Follow Up By: Dean K3 - Thursday, Aug 25, 2016 at 16:09
Can't fix stupid -so I won't bother providiing suggestions or ideas for anybody who has issues,
I might not be a "electronic engineer" but with over 8 years of radio comms and remote area power generation using trailer mounted repeater links for australia's biggest Iron companies means I might have idea or two.
But obviously I am wrong
good luck don't blame us mere plebs when things go up in smoke
FollowupID: 873429
