EOTrackMe
Submitted: Wednesday, Aug 24, 2016 at 13:12
Member-George (WA)
Tried using EOTrackMe on my Galaxy S4 and I get an error message "Server : Your member record is invalid"
I have never had this before, does anyone know what it means ?
Reply By: ExplorOz Team - Adele - Wednesday, Aug 24, 2016 at 19:08
Hi George, have you entered your User ID as per the EOTrackMe Android help file? And have you purchased the registration for the EOTrackMe Android App from the
Shop yet?
603785
Reply By: Member-George (WA) - Wednesday, Aug 24, 2016 at 19:20
Hi Adele, I have EOTrackMe on my Galaxy S4 for several years and it has worked perfectly up till yesterday when I started to receive the Error message. I have just now checked my ID and it had my email address there. Now changed that with my ID number. I will let you know if it works now. Cheers
603787
Follow Up By: Member-George (WA) - Thursday, Aug 25, 2016 at 13:35
I Adele, no longer getting the error message. However, EOTrackMe is not showing any info, i.e Lat. or Long. etc. At he top it shows "GPS paused" and then changes to "GPS started, waiting for a fix" and then scrolling back to paused again.
The only indications shown are : Satellites :18, Server : On line.
Not sure if my EOTrackMe app is corrupted or a problem with my Galaxy S4.
Any thoughts ?
873412
Follow Up By: ExplorOz Team - Adele - Thursday, Aug 25, 2016 at 15:30
Hi George,
Firstly, the email address appearing in the User ID field would have definitely been the cause of the first error, so I'm glad to hear that this is resolved. The second error that you are reporting above sounds like an issue with the Device's GPS - is this still occurring or has the problem resolved itself?
873418
Follow Up By: Member-George (WA) - Thursday, Aug 25, 2016 at 15:32
Hi Adele, still occurring
873419
Follow Up By: ExplorOz Team - Adele - Thursday, Aug 25, 2016 at 15:35
Hi George,
Perhaps
check the app's permissions. Open the Settings Menu on your phone, there should be a heading called Apps or Application Manager, open this and select EOTrackMe, then tap on Permissions and make sure the app has permission to access your location.
873420
Follow Up By: Member-George (WA) - Thursday, Aug 25, 2016 at 15:41
Hmmmm, It tells me 'Directory is empty' yet the app still loads
873421
Follow Up By: ExplorOz Team - Adele - Thursday, Aug 25, 2016 at 15:42
George, where does it say that?
873422
Follow Up By: Member-George (WA) - Thursday, Aug 25, 2016 at 15:45
File Manager > Device > EOTrackMe
873423
Follow Up By: ExplorOz Team - Adele - Thursday, Aug 25, 2016 at 15:47
Ok, that just means that the app doesn't have a current stored tracking log - did you go into settings and
check the location permission as per my instruction above?
873424
Follow Up By: Member-George (WA) - Thursday, Aug 25, 2016 at 15:58
Under Permissions : This phone can access the following on your device,
Read phone status and identity
Approximate location (network based) precise location (GPS and network based)
Modify or delete the contents of your SD card, Read the contents of your SD card
Find accounts on the device, use accounts on the device
Full network access, view network connections
Run at start up
873425
Follow Up By: ExplorOz Team - Adele - Thursday, Aug 25, 2016 at 16:02
Thanks George, that all sounds correct, it sounds like there could possibly be an issue with the GPS signal. Are you testing the device inside or outside? As giving the phone a clear view of the sky could resolve the problem.
If that still doesn't work, just let me know and I will give you a call so that we can wrok through it further (easier than posting back and forth in the
Forum).
873426
Follow Up By: Member-George (WA) - Thursday, Aug 25, 2016 at 16:03
tested outside
873427
Follow Up By: Member-George (WA) - Thursday, Aug 25, 2016 at 16:05
Hi Adele, problem solved, EOTrackMe now works fine.
Solution : Switched off the phone, removed the battery, put it back together, switched on the phone, activated EOTrackMe. All good.
Sorry to take up so much of your time. Cheers
873428
