2013 V8 landcruiser fuel problem
Submitted: Friday, Sep 23, 2016 at 11:52
Member - Cobba
I a loosing power and the vehicle is surging after approx 60 kms of travel. I have had the the vacuum valve replaced but the problem persists. After a restart I can get around 60ks and the car surges again with the engine light eventually coming on and shutting down the motor . Any have any clues?
Regard
Cobba
Reply By: TomH - Friday, Sep 23, 2016 at 12:16
Join Lcool who are the Toyota Gurus. Its Free
You might have something LOOSE which could make you LOSE power
604581
Reply By: Malcom M - Friday, Sep 23, 2016 at 12:33
you've done the obvious like filters?
604582
Reply By: 865 - Friday, Sep 23, 2016 at 13:02
Buy yourself a scan Guage ,it will give the codes for any problems. Guage is approx $160 from eBay ,code definitions can be found on the Internet .You will then be in a position to diagnose any future problems
604584
Reply By: Top End Az - Friday, Sep 23, 2016 at 13:09
Sorry if I'm missing something but is it a petrol or diesel?
604586
Reply By: tonny a - Friday, Sep 23, 2016 at 14:10
Hi Cobba
This happened to me only about 6 weeks ago. Was told it were 4 fuel injectors.
Engine made a knocking sound and I could only drive about 30 km.
Was towed to the Toyota dealer in
Broome to find out is was a fuse.
Good luck.
Tonny
604590
Reply By: Erad - Friday, Sep 23, 2016 at 16:12
To me, it sounds as if the vent sysem in your fuel tank may be blocked. When it stops again, open the fuel cap and see if a surge of air rushed in. If it does, that may be the problem. Also,
check the temperature gauge etc to see if something is overheating (I don't think this is the cause).
604594
Reply By: Member - JOHN C16 - Friday, Sep 23, 2016 at 16:42
Check the earth wire for the fuel pump ECU. The wire can be loose or the bracket it is attached to can be broken causing intermittent interruption to fuel flow. This is one of the few possible causes that is easy and cheap to fix.
Good luck,
604596
Reply By: Member - Phil G (SA) - Friday, Sep 23, 2016 at 19:42
Unusual for a near new vehicle. What aftermarket mods have been done?
604599
Reply By: Member - Leigh (Vic) - Friday, Sep 23, 2016 at 21:39
I am surprised the dealers cannot identify the problem from the fault codes. I assume you have had log book servicing by them and still in warranty period etc?
604601
Reply By: member - mazcan - Tuesday, Sep 27, 2016 at 19:03
hi
if you have fuelled up prior to the problem occurring my guess is the filters are partly blocked with contaminated fuel starving the engine
clean or replaced filters are only good until the next lot of dirty fuel enters the system
all the best
604699
