Hema Explorer
Submitted: Thursday, Sep 29, 2016 at 12:40
TonyL2450
Wondering if there are any travelers out there running Hema Explorer on a Samsung Galaxy TAB 2?
Your opinion on the pros and cons would be appreciated.
Safe Travels,
Reply By: Member - wicket - Thursday, Sep 29, 2016 at 15:19
I have it on an iPad, bought it on special for $30 plus an extra 20% off by using officeworks permanently discounted cards.
The maps are very nice especially when zoomed out so trip planning is somewhat easier than with the ExplorOz app and you can manually plan a route easily which isn't the case with Exploroz app.
I like them both ,more
places of interest shown with the Exploroz app and the
treks are a bonus.
As I'm a bit of a mug I also have a number of other map apps , they all do things a little bit differently so at various times I will use several.
Wait till it's on special again then grab a copy.
604744
Reply By: Tony F8 - Friday, Sep 30, 2016 at 17:53
I run Memory Map, which is the platform used by hema, on a samsung 10.1 note and love it. I personally prefer the memory map packages as you get hema as
well as oztopo maps and don't have to pay the ridiculous upgrade fee that hema want to charge you.
604780
Reply By: MarkLH69 - Friday, Sep 30, 2016 at 21:34
Use it on a Samsung Tab S 10.5 which is older and it's pretty good.
Had to get a 2A charger and a dedicated USB charge cable to keep it charged though.
Otherwise the battery level would be dropping as it consumed more current than it was getting.
604788
Reply By: Kevin S - Life Member (QLD) - Sunday, Oct 02, 2016 at 14:38
I was using Hema Explorer on aTab 2 but I also have EO Traveller that I now use as I like it better. Good clear maps with multiple zoom levels and the maps are more up to date than Hema's.
Cheers, Kevin
604830
Follow Up By: TonyL2450 - Sunday, Oct 02, 2016 at 15:30
Thank you Kevin and the other peoples that helped me make an informed decision.
Will buy the EO Traveller on SD micro chip and hopefully this will fit into my Garmin nuvi and Samsung Tab2 .
874628
Reply By: Sigmund - Monday, Oct 03, 2016 at 10:50
Version 3 of Hema Explorer runs to over 5 gig storage with all the standard maps, so it's either get plenty of memory or just install the state or two that you need (and remember to change them if heading elsewhere). These are the 150 K or so maps.
I only upgraded to 3 as I'd got 2 on special for something like $20 (Android version). While the scale is improved I retain doubts about the accuracy. My first
check against an area I know
well in the
Vic high country showed one walking track as a vehicle track, a mountain labelled with a name that was changed several years ago, only a limited number of track names and no gates. But the maps are nicely drawn and the contours useful.
I'm a fan of the large scale contour maps produced by the States (25K and 30K in Vic) and these come with the added subscription version. But I already have Oztopo for Garmins that covers the country at c. 25K and will stick with it for the moment.
604858
Reply By: maurice b - Tuesday, Oct 04, 2016 at 01:01
Correct me if wrong i'm pretty sure it won't work is your Nuvi as its a different operating system
604872
Reply By: Member - TonyL2450 - Tuesday, Oct 04, 2016 at 02:35
Yes and Thanks Maurice. I believe your definiately right after reading into it further.
604873
