Site Search
Section Image
Dont mention duel batteries again Plan B
Submitted: Thursday, Jun 03, 2004 at 02:34
fat bastard
1. Main cranking battery 'A' no direct connection to battery 'B
2. Battery 'B' is being charged by a battery charger through an 240 volt inverter
3. Spend one third of the dollars and get a good charge on to the axuaillary deep cycle battery, unlike a charge through an alternator.
4. No expensive dual battey setup.
5. No problems with solenoids geting stuck
6. All accessories from the deepcycle
7. No Auto electrician with fancy circuts. Buy off the shelf cheap
8.Battery 'B' is automatically charging as the car is started up.
Could anyone who has a better understanding of these matters, could they any check for flawed thinking.
Thank U FAt Boy
Advertisement
ThreadID: 13410 Replies: 12
Views: 353 FollowUps: 15
AnswerID: 61465   Submitted: Thursday, Jun 03, 2004 at 06:45
Andrew & Jen (Melb) replied:
I have always thought that something like that sounds sensible but have thought that it was somewhat inefficient to change from 12 to 240 with the inverter only to change it back to 12 again. The other issue is that the Deep Cycle batteries seem to take ages to charge fully and you might have to drive around for 15 hours per day. Also if you use a bigger charger, you might need a bigger inverter. Have never done the sums to work out how it would go.
Yes - Luke's got a bigger one than me
Click Image to Enlarge
2001 Landcruiser 100S Turbo Diesel
"We do not stop playing because we grow old; we grow old because we stop playing"
Reply 1 of 12
FollowupID: 322960   Submitted: Thursday, Jun 03, 2004 at 14:29
fat bastard posted:
Never thought of that, thanks Andrew.
The fat one.
AnswerID: 61467   Submitted: Thursday, Jun 03, 2004 at 07:31
Lone Wolf replied:
Did I miss the bit about the really really looooooong extension cord?
Reply 2 of 12
AnswerID: 61469   Submitted: Thursday, Jun 03, 2004 at 07:42
Peter replied:
Have a look here at the twin charge battery charge controller
http://www.12volt.com.au/webcat2003/daulbatt.html
Seems like a good idea just connect to relay to ignition and away you go.
Reply 3 of 12
FollowupID: 322933   Submitted: Thursday, Jun 03, 2004 at 09:00
Rosscoe posted:
I keep reading about the Arrid Twin Charger, which is also described on the sight you nominated.
Do you know of anyone who has used this device and are claims of 100% charge, correct.
I've been quoted $78 (No-name) to $300 (Arrid) with similar claims of 100% charge.
I have dual batteries in my 4WD with a Sure Products Smart Separater and third battery in my dirt road van. It's this third battery I want to get to 100% charge while I'm on the road.
FollowUp 1 of 4
FollowupID: 322946   Submitted: Thursday, Jun 03, 2004 at 12:08
phil posted:
The ARRID Twin Charge appears to be an inverter syatem which accepts unregulated 12v and delivers an appropriate charging voltage and current for the auxillary battery. They are limited to 20Amp.
This system should be excellent for batteries which are remote from the main battery, especially in camper trailers etc. because it removes the voltage drop in the cable from consideration and should ensure a fully charged battery, if you can wait long enough! 20 amp is plenty for a deep discharge battery.
FollowUp 2 of 4
FollowupID: 322962   Submitted: Thursday, Jun 03, 2004 at 14:36
fat bastard posted:
Peter thanks kindly for that wonderful piece of info
Fat Guts
FollowUp 3 of 4
FollowupID: 323119   Submitted: Friday, Jun 04, 2004 at 10:24
Rosscoe posted:
G'day Phil,
That's what I understand. But I'm hearing conflicting reports as to how it handles the output. Some say it is not a "smart" charger", others say its a 3-stage charger, and still others say it simply outputs 14 V DC for inputs down to 9 or 10V.
The last two comments come from different distributors.
Arrid refer me to their distributors for technical inquiries.
If it only puts out 14 V then the current into the battery will be insufficient to "fully" charge the battery once the battery voltage rises to that value even though it can deliver 20A.
Can some one explain how these things work
FollowUp 4 of 4
AnswerID: 61470   Submitted: Thursday, Jun 03, 2004 at 07:42
Peter replied:
Reply 4 of 12
Activities Index
Luxury Yacht Romantic Overnight Stay for 2 Luxury Yacht Romantic Overnight Stay for 2
Sydney - NSW
A truly romantic experience.
Inverawe Native Gardens Tour Inverawe Native Gardens Tour
Hobart - TAS
Meet the creators of the Inverawe Native Gardens.
Overnight Stay in Kangaroo Valley for 2 Overnight Stay in Kangaroo Valley for 2
South Coast - NSW
Why not experience accomodation on a beautiful horseriding property surrounded by the spectacular mo
V8 SUPER DRIVE - SA V8 SUPER DRIVE - SA
Adelaide - SA
Experience V8 Racing / Driving at its best, with the best, you and a professional race car driver be
Book Now - Things To Do
AnswerID: 61473   Submitted: Thursday, Jun 03, 2004 at 08:10
Dave from Fraser Coast 4WD Club replied:
THe inverter and charger will take more juice to run than they will put out, I guess that if you have a really high out put alternator, this will be fine.
COnsider also that whe the car is running (and charger is charging the batteries) there will always be some drain on the 2nd battery (you say that everything is running off it) therefore your charger will be outputing at max output all the time, this is not good for the charger.
By making this simple system with "no solenoids getting stuck" and no "fancy circuits" you have made a much more complicated and extremely inefficient system.
Talk to your auto electrician about making a diode pack that will allow you to 'trick' the alternotr (or regulator more precisely) into a higher output voltage if you really want to be able to "cook" the DC.
or do what more and more people are doing and forget the DC and go for a hybrid like the exide extreme.
Is your car diesel?? if so, have you considered that you will be trying to glow the motor off the 2nd battery, not a great idea.
Seriously DB setups aren't hard to do, mine works a treat and is very simple to operate (TJM IBS) it wasn't that expensive and I've only had to replace 1 solenoid (last year) in 6 years. In my books, with the treatment that my truck recieves, that's pretty good!
I know that you are trying to think outside the box, but in all seriousness, I think that you'll end up with dramas and will then spend the money on a DB anyway.
Fraser Coast 4WD ClubFraser Coast 4WD Club
Business Member: My Profile
Reply 5 of 12
FollowupID: 322965   Submitted: Thursday, Jun 03, 2004 at 14:40
fat bastard posted:
Thanks Dave for that very involved and well thought through response.
Old Blubber
AnswerID: 61475   Submitted: Thursday, Jun 03, 2004 at 08:48
Member - Pesty (SA) replied:
If Batt b is flat and you drive for an hour you could expect a 100 amp alt to put in 30-40amps , but a 10amp 240 charger ( physical size will restict you) will only put in about 6-8 amps in the same time.
Forget all the crap and buy yourself a 80 amp relay and wire it in to come on when ignition is activated and put an 80 amp lead to the batt b and presto less than $60. jobs done.
As an added back up if it breaks down while away you can put a jump lead across batterys during the day and unclip at night to keep yourself going.
Pic 1 Mad Max Hill Silverton
Pic 2 Camped on beach at Tiddy Widdy
Happiest Cruiser-in Oz !!
Reply 6 of 12
FollowupID: 322967   Submitted: Thursday, Jun 03, 2004 at 14:43
fat bastard posted:
Well done Pesty, concise and clear and easy to follow for us novices.
Object of Fatness
AnswerID: 61482   Submitted: Thursday, Jun 03, 2004 at 12:10
Cruisergxl replied:
I have my set up wired to a second oil pressure switch so that in addition to being wired through the ignition so it will only come on when the engine is actually turning over.
I actually use two 30 amp relays in parallel, not an ideal solution but I happened to have them and they are voltage spike protected witha couple of zener diodes across their coils.
Whole thing seems to work fine thus far, have never actually got out the hydrometer to check if the battery is fully charged.
As said before in the rare situation that you need to use your auxillary to assist starting then get out your jump leads!
Chris
Reply 7 of 12
FollowupID: 322969   Submitted: Thursday, Jun 03, 2004 at 14:47
fat bastard posted:
Chris u appear to be completely on top of your own personal system, with a good knowledge of electronics. The second oil switch is a nice touch.
Complete Fatness
AnswerID: 61486   Submitted: Thursday, Jun 03, 2004 at 12:41
Member - Jeff M (WA) replied:
Ineffeciant is the key here I think, not to mention that you should turn your inverter off before doing any serious water crossings (zzzap!) hee hee.
There are much simpler ways to go about it (mentioned above), my little Jaycar (silicone chip) system works great, give me less than a 0.05v voltage drop through the isolater, diodes are great but they can have a 0.5v voltage drop!
My whole system cost me $60 bucks (already had dual bats in paralell) and it charges the deep cycle pretty damn good, it'll show 14v on the display while charging without the headlights on.
I still whip out the 240v charger and give it a good fry before we go away on a trip though, just to make sure.
#1 - I'm not telling :-)
#2 Yellowdine National Park
#3 Powerline Trek - Saywers Valley
#4 Near Hyden WA
#5 Pinjar Pines
Reply 8 of 12
FollowupID: 322970   Submitted: Thursday, Jun 03, 2004 at 14:50
fat bastard posted:
I like it Jeff............ Thse Kiss principle.........'
Well done
Fattybombar
AnswerID: 61489   Submitted: Thursday, Jun 03, 2004 at 13:20
Truckster (Vic) replied:
LMAO with all the confusion, I just went a piranha system.. it works, 30mins to fit, wasnt cheapest on earth, but ... WORKS.
Reply 9 of 12
FollowupID: 322958   Submitted: Thursday, Jun 03, 2004 at 14:00
Shawn posted:
Same here Truckster, but I ended up getting it cheap, the fella forgot to charge me for the battery tray and battery, what a deal.
Shawn
FollowUp 1 of 3
FollowupID: 322971   Submitted: Thursday, Jun 03, 2004 at 14:52
fat bastard posted:
Cant argue with something tried and true.
Thanks Truckster and Shawn.
The Fat one.
FollowUp 2 of 3
FollowupID: 322975   Submitted: Thursday, Jun 03, 2004 at 15:20
Baz (NSW) posted:
fat, we have the Arrid twin charge system it suits us because the second batt is in the camper, and it is claimed that it increases the voltage when it detects voltage drop so as to keep charging the second battery at the desired rate, but it's a personal choice if the system you have now works, dont change, we did what was best for us, took a little longer to install but whats 1/2 hour or so.
Baz.
FollowUp 3 of 3
AnswerID: 61516   Submitted: Thursday, Jun 03, 2004 at 16:25
Magnus replied:
Fat,
The other posts have address the charging while going issue. What about when you are stopped in one place for a week because the fishing is good or the scenery is great etc.
You will need to top up the second battery if it running all the camp gear with a generator, running the vehicle or a solar panel.
Good gen sets will set you back about $1k and a decent solar panel to put out 2 amps about $400 or so.
If you are staying put for any length of time you need to calculate your daily amp draw and arrange a way to replace that daily draw down or let your battery go flat.
Magnus
Reply 10 of 12
FollowupID: 323082   Submitted: Friday, Jun 04, 2004 at 00:11
fat bastard posted:
Brilliant. Solar is no big deal these days prices are dropping every year.
Thanks Magnus
Oh tunnel bellybutton
AnswerID: 61532   Submitted: Thursday, Jun 03, 2004 at 18:30
Mrs Diamond replied:
are you confused yet lol.
Reply 11 of 12
FollowupID: 323083   Submitted: Friday, Jun 04, 2004 at 00:14
fat bastard posted:
Just wetting my appetite. There is nothing more fulfilling than, to have a problem, research it and get right.
Guru of Fatness
AnswerID: 61545   Submitted: Thursday, Jun 03, 2004 at 19:01
Jimbo replied:
Lardarse,
Be very wary about Pirahna, they are EXPENSIVE. Talk to a few auto elecs about a simple or smart solenoid. Also consider an AGM battery as they can absorb a huge charge in a short time. Conventional deep cycles batteries dont like to absorb more than about 5 A/h regardless of what your alternator is putting out.
Regards,
Jim.
Reply 12 of 12
FollowupID: 323084   Submitted: Friday, Jun 04, 2004 at 00:18
fat bastard posted:
Big Bad Jimbo I love man who can steer me clear of expensive options. My wife certainly cant.
Fee foe fiy fum I can smell the bum of a fat one
Activities Index
Adelaide - SA
Golf Lesson - WA Golf Lesson - WA
Peel - WA
If you love golf or know someone who does why not try a golf lesson with one of our PGA professional
 The Revival - aroma spa, massage and facial The Revival - aroma spa, massage and facial
Macedon Ranges - VIC
Our Revival pamper session starts with a 30 minute aroma spa that helps the body and mind reach a de
Rainforestation Nature Experience Rainforestation Nature Experience
Cairns and Tropical North QLD - QLD
Get back to nature with this experience.
